Heserin default timeout period
Results 1 to 2 of 2
    Aug 2004
    Default Heserin default timeout period
    Is there any default timeout period for Heserin command if I do not give any timeout figure and Label.?
    One friend told me that "if you donot use the timeout in the command the program never leave that line until receive the right expected data". Is it true ? because I was thinking that the default value is 65535 ms if I do not use any timeout figure there.
    Thanks in advance for your kind replies.
    Ero
    Default Re: Heserin default timeout period
    No, not as far as I know.
    If you don't specify a timeout it will wait untill it has received the correct number of bytes or, if using the STR modifier, it sees the termination byte. If no data is comming in it will sit there waiting...forever...
