Newbie - failed at the first hurdle on Mels RTC!
Results 1 to 9 of 9
    Mar 2011
    Somerset UK
    Default Newbie - failed at the first hurdle on Mels RTC!
    Hi All,
    I'm a noob here so please be gentle with me 'til I get the hang of things (please!) - lol
    I've tried compiling Mels Real time clock program as I want to build a clock circuit & I got these errors:
    PICBASIC PRO(TM) Compiler 2.47, (c) 1998, 2006 microEngineering Labs, Inc.
    All Rights Reserved.
    PM Assembler 4.08, Copyright (c) 1995, 2006 microEngineering Labs, Inc.
    Error C:\PBP\MELS_C~1.ASM 166 : [225] Undefined Symbol 'pic16F628'
    Error C:\PBP\MELS_C~1.ASM 172 : [225] Undefined Symbol 'pic16F628'
    Error C:\PBP\MELS_C~1.ASM 178 : [225] Undefined Symbol 'pic16F628'
    Error C:\PBP\MELS_C~1.ASM 184 : [225] Undefined Symbol 'pic16F628'
    Error C:\PBP\MELS_C~1.ASM 190 : [225] Undefined Symbol 'pic16F628'
    Error C:\PBP\MELS_C~1.ASM 196 : [225] Undefined Symbol 'pic16F628'
    Error C:\PBP\MELS_C~1.ASM 202 : [225] Undefined Symbol 'pic16F628'
    Error C:\PBP\MELS_C~1.ASM 208 : [225] Undefined Symbol 'pic16F628'
    Error C:\PBP\MELS_C~1.ASM 272 : [225] Undefined Symbol 'CMCON'
    Warn C:\PBP\MELS_C~1.ASM 750 : [102] Code Crosses Boundary @ 800h
    *** 13 Errors ***
    So I changed all references for pic16F628 to pic16F887 and tried again, this time I get the following errors:
    *** 5 Errors ***
    I've tried searching for answers on here and have found the solution to the boundry error, but I can't figure out or find any info about the other errors I'm receiving? I would post the code, but it's exactly as I downloaded it from here!
    Any help or pointers would be very much appreciated, thank you.
    Default Re: Newbie - failed at the first hurdle on Mels RTC!
    Hello hu lee gan,
    Welcome to the forum,
    For starters, you could make our lives much easier if you were to post the link to the source code so we do not have to hunt and hope we are looking at the correct code. Thank You.
    Ok the code as loaded into Microcode Studio should be something like this:
    ' Olympic Timer
    ' Melanie Newman
    ' 05/Aug/2004
    ' Topical Program demonstrates use of Interrupt
    ' Driven Background TIMER, to time events down to
    ' one one-hundredth of a Second (1/100 Sec).
    ' Bonus CALIBRATION Feature allows simple adjustments
    ' in 360mS steps per hour. This calibration adjustment
    ' range is limited to +/- 36 seconds per Hour.
    ' This program is for 4MHz clock (1uS Timer Ticks).
    ' PIC Defines
    ' Change these defines to suit your chosen PIC
    @ DEVICE pic16F876, XT_OSC ' System Clock Options
    @ DEVICE pic16F876, WDT_ON ' Watchdog Timer
    @ DEVICE pic16F876, PWRT_ON ' Power-On Timer
    @ DEVICE pic16F876, BOD_ON ' Brown-Out Detect
    @ DEVICE pic16F876, LVP_OFF ' Low-Voltage Programming
    @ DEVICE pic16F876, CPD_OFF ' Data Memory Code Protect
    @ DEVICE pic16F876, PROTECT_OFF
    ' Program Code Protection
    @ DEVICE pic16F876, WRT_OFF ' Flash Memory Word Enable
    ' Hardware Defines
    ' LCD
    ' . . . . and so on and so forth . . .
    The computer before me right now does not have MCS installed so bear with me . . . in the tool bar at the top is a list box where you are supposed to select the PIC you are using. When you select the chip MCS automatically links the correct PIC.BAS files and PIC.INC files to your code, if the correct chip is not selected you will get compile errors.
    In the toolbar there are Editor and Compiler options, I think under the view button. It is there where you can choose whether to use MPASM or PM assemblers, what kind of file to output, what programmer you want to use, and a host of other goodies. Again if something does not agree with your code, then you get errors.
    Additionally, if you wish to include Config Fuse settings in you code, you will need to go to the PBP Root Directiory and open the " .inc " file, in this case P16F628.inc, and comment out the default config statements there, if you do not it will throw errors at you and disregard the configs in your code.
    Required reading below:
    Mar 2011
    Somerset UK
    Hi Joe S. - Thanks for taking the time to reply, First off here's a link to the code I'm using and the pic I'm using is a 16F1887:
    http://melabs.com/resources/samples/...ted/mn1307.txt
    I'm in work at the moment so won't be able to try anything until later, but thanks for the info
    Mar 2011
    Somerset UK
    Talking Re: Newbie - failed at the first hurdle on Mels RTC!
    Right... I've read through the two threads you gave me the links to and thanks to you, it now compiles
    But it's not working - lol - I suspect I've wired something up incorrectly as I'm getting output on the screen, but no the time & date - just zero's!
    You've given me plenty of food for thought now, so I'll disappear back into the lab and report my findings
    Once again, thanl you for taking time out to reply - it is very apreciated.
    First off . . . You are Welcome, it is always a pleasure to help someone who appreciates it.
    IF my Fuzzy foggy memory serves me correctly, yo need some pullup resistors on those RTC data lines . . . I THINK. Since I never actually assembled that project, I am not sure.
    Mar 2011
    Somerset UK
    Right - First off, cheers bud, your pointers have allowed me to get this up 'n running and working perfectly - I owe ya a pint (or two!)
    I've shelved the 16F887 and written the code to a 16F628 instead, I reckoned being a noob, it might be better to try and get my head around 'less legs' - lol and it has worked for me, I've now got a nice little RTC running on my desk and as sad as it might sound, I'm chuffed to bits with my first project.
    The next thing I want to do is write some code to output the Date & Time data to RS232 when a button is pushed, but I've run out of memory on the 16F628 as Mel's code takes up pretty much all the memory that is available! I had enough space to write the code for the button monitoring... but literally didn't have enough space for the 'serout' command line - lol
    Close, but no cigar...
    I've ordered some 16F648's to allow me to 'port' this over seemlessly (hopefully anyway!) and will post back my findings... or failures... probably failures knowing me, but I'll get there in the end
