Greetings,
I'm trying to make a bit of code to produce a random number between 0 and 9.
I've seen some discussions here about this pseudo-random but i have some questions.
1- when executing the "random var" command, will it generate values until the next line of code? or... when it will stop generating numbers ?
2- Is it possible to keep it generating numbers in the background and call the variable at some point of the code to check the value at that specific time ?
