"was" command
Results 1 to 3 of 3
Thread: "was" command
    Jan 2010
    Default "was" command
    Hello All,
    Minor brain cramp trying to figure out a small coding problem. Probably an easy solution, but having trouble seeing it.
    I have a loop in my code that continuously monitors multiple inputs. These inputs are buttons, but the last one is an external input from an outside source.
    The buttons can be individually programmed to do either A or B depending on what the last input is doing. Button 1 can be assigned to do task A when the last input is high and Button 2 can be assigned to do Task B when the last input is high (and swapped at some later time).
    My dilemma is this: I have the code to say:
    if lastinput = 1 then ' if input is on,
    value = 1 ' then show on,
    value = 0 ' else show off
    What I want to say now is:
    If lastinput was 1 and is now 0 then go do this.
    How do I go about doing a "was" command?
    Tony
    Default Re: "was" command
    Maybe an edge triggered interrupt is what you need?
    Dec 2005
    If is <> was Then
      was = is
      If is = 1 Then
        go do something
      EndIf
    EndIf
