HT16511+pic12f629
Results 1 to 3 of 3
    Jan 2011
    Default HT16511+pic12f629
    Hello!
    I'm trying to make a VFD work with a pic12f629. VFD is taken from a car radio and it's driven by HT16511 from Holtek. I've made the program but before programming the pic, please can someone tell me if it's okay or not?
    @ __config _XT_OSC & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _PWRTE_OFF
    CMCON =7	        ' Disable analog comparator
    TRISIO =%00000000
    GPIO=0
    DEFINE SHIFT_PAUSEUS 100
    DPIN    VAR GPIO.0
    CPIN    var GPIO.1
    STB     VAR GPIO.2
    command2 var byte : command2=%01000100
    command3   var byte : command3 = %11000000
    command1  var byte : command1 =%00001101
    command4  var byte : command4 =%10001111             'display on, pulse width 14/16
    segment   var byte : segment=%11111111
    gosub led_display
    Led_display:
    low stb
    shiftout dpin, cpin,4,[command1]       ' set display mode
    high stb
    low stb
    shiftout dpin, cpin,4,[command2]       'Data setting commands
    high stb
    low stb
    shiftout dpin, cpin,4,[command3,segment]              'Address setting commands (segment should light up 8 segments)
    high stb
    low stb
    shiftout dpin, cpin,4,[command4]       'Display control commands
    high stb
    pause 200
    I have attached HT16511's datasheet. Thank you
    Sep 2005
    delhi
    Question Re: HT16511+pic12f629
    have u used ht 1621 to drive custom lcd ,pl. give some example if you have done.
    i have little knowledge about these.
    thanx
    tercelugt's Avatar
    tercelugt Guest
    Default Re: HT16511+pic12f629
    Interestingly, as I seek to work with the most PIC12F629 LM7001, 88-108 MHz
