how can I test a bit in a arrow
Results 1 to 5 of 5
    Mar 2011
    Question how can I test a bit in a arrow
    hello,
    I would test a bit in a buffer of arrow
    I have a buffer of 8 bytes
    for exemple:
    buffer var byte[8]
    buffer[0] = %11110000
    buffer[1] = %10011010
    if buffer[1].2 == 1 then ... 'test bit 2 of buffer[1]
    (the value is just an exemple)
    but "buffer[1].2" don't work and return an error
    ERROR Line 93: This style array syntax not supported, (test.pbp)
    how can I test a bit in a arrow?
    Default Re: how can I test a bit in a arrow
    Bit 2 of the second byte in the array would be bit 10 in the array, correct?
    So, IF Buffer.0(10) == 1 THEN
    For more in depth information please see this thread.
    Quote Originally Posted by kik1kou View Post
    Another idea to test bits of an array variable, use a temp variable
    TempVar = Buffer[1]
    If TempVar.2 == 1 then.....
    Mar 2011
    TempVar = Buffer[1]
    yes I do the same, but I thinked have more simple code for do it
    sorry for the english 'arrow => array' ;-)
    That would be great if there was a direct way to do it like you wrote, but I don't know any way to do it AS-IS.
    sssshhh, that will be our secret Don't worry... i'm not English either.
