Powering a PIC
Results 1 to 12 of 12
Thread: Powering a PIC
    Sep 2006
    Default Re: Powering a PIC
    Dave,
    where can i read up on these UL requirements? (www.ul.com) but do you have a pdf document with these norms.. i could not find it. So basically you are telling I need a switching supply ? no transformer ?
    k
    my 2 cents.
    When you design something, you must use a whatever kind of PSU that meet at least the minimum current needed by your target application.
    Then the safety. Anything in your design will be controlled by the end user? If so, can the enclosure be enough insulation to avoid shock hazards? If so... does it really worth to sacrifice safety against few bucks more PSU design assuming your enclosure is big enough to fit a Transformer or already built PSU (Switching or else)?
    In some situation, transformerless PSU are great, while can be dangerous in some other situations. Transformers are not that expensive, but have input voltage & Frequency range, while many Switching PSU will work in any country without any modifications but the AC prong.
    If you look for a WallWart, some wall-wart are shipped with replaceable AC prongs. They are somehow interesting for worldwide use/target.
    Dec 2005
    Quote Originally Posted by lerameur View Post
    Sorry, it's been a few years since I investigated this. The biggest issue is UL wants to have ongoing access to your operation to verify assembly operations. It's just not practical for a small business - you're better off using approved external modules like the $5 wall transformer I referenced. While I'm not familiar with the internals of the Spark Fun PS, most of these have internal transformers (at a high frequency) and provide isolation from the power line.
    You could design a switch mode supply into your device and choose an offshore assembler that can meet UL requirements but, again, this really isn't practical (or cost effective) for a small business.
    California already has power supply efficiency standards that can only be met by use of a switch mode supply. Other jurisdictions are sure to follow.
    Why does your design have an isolation transformer? Are you doing power line communication?
    If you feel lucky, and if there's room... wind some extra turn on the secondary side of the isolation transformer...
    Sep 2006
    I need 200 watt at 120VAC. I already have a big transformer that I am using. So I want to use a bit of the power out of that to supply my PIC. I would also like this to be safe and regulated because I would like to eventually commercialize this.
    K
    Dec 2005
    Many chipmakers offer SMPS chips.But, if you commercialize your product, it would be prudent to get UL approval. Otherwise, one fire plus one attorney could bankrupt you.
    Keeping in mind all the safety matters, look also here:
    http://www.picbasic.co.uk/forum/show...former+elektor
