I have an array of bits (MB_Inputs) to which I want to shift in data from an external device. After trying a couple of different things without luck I came to think of Darrels writeup on the EXT modifier and thought I'd give that a try:and then later onCode:DataIn VAR WORD EXT @DataIn = _MB_InputsThis actually seems to work but when compiling I get an assmebler error 108, Illegal character (,) on line 1532 in the ASM file, that particular line is:Code:ShiftIn PortB.0, PortB.1, 0, [DataIn \16]Questions:Code:DataIn = _MB_Inputs
1) Any idea why I get the error? I hope it's not the underscore "inside" my variable name...
2) Since it, despite the error message, seems to work on the target should I just disregard the error? (Hard to do but I guess I can be convinced)
3) Any other way of shifting data directly into an array of bits using ShiftIn?
I know this may look weird as I could just as well have used a WORD to begin with but it is what it is.
Thanks!
