Turn off HPWM?
Results 1 to 5 of 5
Thread: Turn off HPWM?
    Aug 2009
    Default Turn off HPWM?
    Once you turn on HPWM, can you turn it off?
    Example: (Melanie's LCD Contast?Backlight tips)
    Perth, Australia
    Default Re: Turn off HPWM?
    It may differ from PIC to PIC so check the data sheet, but taking the 18F1320 as an example, the following would turn off HPWM:
    CCP1CON=0
    "I think fish is nice, but then I think that rain is wet, so who am I to judge?" - Douglas Adams
    Aug 2005
    Michigan, USA
    Depends on what you consider "off". If you set the duty cycle to 0% and leave it there your output pin will be '0' (low). If you set the duty cycle to 100% and leave it there your output pin will be a '1' (high). You might also put the CCP1 pin into the hi-z input state.
    Regards, Mike
    The one and only question is :
    1) do you want to stop the PWM output ( set it to 0% )
    2) or turn HPWM Module really off ... which is not compulsory, but some kind of " double security ".
    you then can use Timer2 for other purposes ...
    Aug 2009
    Thanks for the replies:
    I wondered about turning off the HPWM in software, i.e. save battery, use Timer2 for other purposes, etc.
    I was thinking about using the HPWM to drive an LCD backlight. I wanted to turn on the backlight ,i.e. start HPWM, with a button push and somehow turn it back off again when no longer needed.
    Charlie
