How best to time a pin state for extended periods of time
Results 1 to 6 of 6
Threaded View
  1. #5
    May 2008
    Italy
    Default Re: How best to time a pin state for extended periods of time
    If Time accuracy is not an issue then a simple routine like this should solve the problem:
    Counter  Var WORD
    IF Pin_1 = 0 then
    PAUSE 1000  ' one second delay
    Counter = Counter + 1
    IF Counter >1800 then Output_3 = 1
    IF Pin_1 = 1  and Counter > 1 then
    IF Counter <= 120 then Output_1 = 1
    IF Counter >120 and Conter <= 1200 then Outpt_2 = 1
    IF Counter >1200 then Output_3 = 1
    Counter = 0
    GOTO Main
    All the time your Pin_1 will go to zero the time check will be activated.
    Cheers
    Al.
