The best solution to at least half of all timing problems is using a timer interrupt. I don't know why so many people avoid that technique!
If you use an interrupt, you can do all your timing in the background.
Charles Linquist
While I don't disagree, when the level of accuracy is as low as this app seems to be, polling the flag seems the easier to understand solution. The OP is looking for time between 0 and 30 minuites. Seems like an INT may be just a bit overkill. Granted, we have no idea what else needs to be done in the program, so an Interrupt may well be the best overall solution.![]()
-Bert
If Time accuracy is not an issue then a simple routine like this should solve the problem:
All the time your Pin_1 will go to zero the time check will be activated.Code:Counter Var WORD Main: IF Pin_1 = 0 then PAUSE 1000 ' one second delay Counter = Counter + 1 IF Counter >1800 then Output_3 = 1 ENDIF IF Pin_1 = 1 and Counter > 1 then IF Counter <= 120 then Output_1 = 1 IF Counter >120 and Conter <= 1200 then Outpt_2 = 1 IF Counter >1200 then Output_3 = 1 Counter = 0 ENDIF GOTO Main
Cheers
Al.
another option with more time to do other things:
Nothing wrong with Aratti's example, just showing another way.Code:counter var word counting var bit turn on 16 bit timer ' @4mHz osc, this will take .065535 seconds to roll over counter = 0 MAIN: IF TxIF = 1 THEN GOSUB TIMESTUFF ' TxIF is the timer interrupt flag 'USER CODE GOES HERE GOTO MAIN TIMESTUFF: TxIF = 0 'clear interrupt flag IF PIN_1 = 0 THEN COUNTER = COUNTER + 1 COUNTING = 1 ENDIF IF (COUNTING) AND (PIN_1) THEN IF COUNTER <= 1830 THEN OUTPUT_1 = 1 ' 1 second = aproxx 15.25 counts IF COUNTER >1830 AND COUNTER <18300 THEN OUTPUT_2 = 1 ' if you want to do anything for time between 20 and 30 mins, here's a good spot for that IF COUNTER >27450 THEN OUTPUT_3 = 1 COUNTER = 0 COUNTING = 0 ENDIF RETURN
-Bert
