Not just as you wrote it, but you can semplify this way:Is there a way to define LEDXs' TRISIO and GPIO and then call LEDX. It would make the repeated use of individual LEDs alot easier.
Now since you don,t need to change the TRISIO then you can write:Code:LED_T_1 VAR BYTE LED_G_1 VAR BYTE LED_T_2 VAR BYTE LED_G_2 VAR BYTE LED_T_1 = %00011110 LED_G_1 = %00000001 LED_T_2 = %00011110 LED_G_2 = %00100000 main: TRISIO = LED_T_1 GPIO = LED_G_1 pause 500 TRISIO = LED_T_2 GPIO = LED_G_2 pause 500 goto main end
.. or in a normal way you can write:Code:LED_G_1 VAR BYTE LED_G_2 VAR BYTE TRISIO = %00011110 LED_G_1 = %00000001 LED_G_2 = %00100000 main: GPIO = LED_G_1 pause 500 GPIO = LED_G_2 pause 500 goto main end
.. again in a more sophisticated way:Code:LED1 VAR GPIO.0 LED2 VAR GPIO.6 TRISIO = %00011110 main: LED1 = 1 LED2 = 0 PAUSE 500 LED1 = 0 LED2 = 1 PAUSE 500 GOTO MAIN END
CheersCode:LED1 VAR GPIO.0 LED2 VAR GPIO.6 TRISIO = %00011110 main: LED1 = !LED1 LED2 = !LED1 PAUSE 500 GOTO MAIN END
Al.
