Setting GPIO and TRISIO
Results 1 to 6 of 6
    Oct 2009
    Utah, USA
    Default Re: Setting GPIO and TRISIO
    I believe your example of defining a variable as "bin" is incorrect. Here is an excerpt from the manual...
    Some examples of creating variable are:
    dog VAR BYTE
    cat VAR BIT
    w0 VAR WORD
    You might also look at the "HIGH" and "LOW" commands as they also make the given pin an output during the "high" command. BUT be careful as they can act "funny" when your code moves on and the pin goes back to an input un-expectedly. Breadboard something up and try the "high/low" command and see if it will work.
    Here is a program that I wrote to interface the 12f683 to a GPS module. It does not directly address your question but it might give you some insight into working with the registers. It is just a piece if code that I had on my laptop that uses the 12f683... You might look through it for examples of defining variables and writing to the registers. It is kind of a mess in organization.
    DO REALIZE that I am by no way a polished programmer!!
    There is a pretty steep learning curve in getting profecient in working with these PIC's.
    The Microchip PIC 12f683 documentation and the PBP manual is (should be) your friend.
    '*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 2/28/2010                                         *
    DEFINE ADC_BITS 8     ' Number of bits in ADCIN result
    define ADC_CLOCK 3    'SET CLOCK SOURCE TO RC = 3
    DEFINE ADC_SAMPLEUS 50
    ' -----[ Initialization   ]------------------------------------------------
    Reset:
    CMCON0     = %00000111 ' Comparators off
    TRISIO     =   %101100
    ADCON0     = %00001100 ' LeftJust,VDD,x,x,AN3,x,ADCdisabled
    ANSEL      =  %0010000 ' -001xxxx Fosc/8, -xxx0000 all pins digital not analog
    IOC        =   %001000 'enable gpio.3 interrupt on change
        'NOTE: you must also clear the CONFIG.5 fuse bit to change gpio.3 to
        'an I/O instead of MCLR (its under the configuration link on the
        'pickit2 programing app. This bit must be done each time before you
        'program the chip.
    OPTION_REG = %10111111 'b7=pullups disabled
                           'b6=int on falling edge
    ' -----[ Timer setup ]----------------------------------------------------
    ' T1CON =  %00110001 'Enable Timer1 with 1:8 prescaler
    ' PIE1  =  %00000001 'Enable Timer1 overflow interrupt
    ' 'PIR1  =  %0000000
    ' TMR1h = 0  'reset timer1 to zero
    ' TMR1l = 0  'reset timer1 to zero
    Xpwr var gpio.0 'Output to turn on XBee
    XBrx var gpio.1 'Output serial data to XBee
    XBtx var gpio.2 'Input
    rst  var gpio.3 'Input
    Gpwr var gpio.4 'Output to turn on GPS
    GPS  var gpio.5 'Input serial data from GPS
    symbol I = 254        'LCD prefix for Instruction
    symbol clr = 1        'LCD CLEAR SCREEN
    SYMBOL LINE2 = 192    'LCD ADDR FOR 1ST CHAR ON 2ND LINE
    SYMBOL H = 2          'LCD HOME COMMAND
    GPRMC VAR BYTE[64]
    hh      VAR BYTE  'hours
    mm      VAR BYTE  'minutes
    ss      VAR BYTE  'seconds
    sss     var word  'milliseconds
    fix     VAR WORD  'GPS fix
    latdeg  VAR BYTE  'degrees latitude
    latmin  VAR BYTE  'minutes latitude
    latminn var word  'fractional minutes latitude
    NS      VAR BYTE  'north or south
    londeg  VAR BYTE  'degrees longitude
    lonmin  VAR BYTE  'minutes longitude
    lonminn var word  'fractional minutes longitude
    EW      VAR BYTE  'east or west
    Knots   VAR byte  'speed in knots (units)
    Knotss  var byte  'speed in fractional knots
    course  var word  'heading
    dy      VAR BYTE  'day
    mt      VAR BYTE  'month
    yr      VAR BYTE  'year
    speed   var byte[4] 'array to hold knots & knotss
    mph     var word    'units of mph
    mphh    var byte    'fractional mph
    KK      var word   'this var will contain knots(12) & knotss(34) = 1234
    Value   VAR  WORD  'AD value, Must be a WORD even though AD is 8bit
    ' -----[ Program Code ]----------------------------------------------------
    'low lcd
    'pause 1000               'allow lcd to initialize
    'serout2 lcd,16780,[i,clr]
    high gpwr
    high xpwr
    'high gpwr
    serin2 gps,188,3000,tmout,[WAIT("$GPRMC,"),STR GPRMC\63\"$"] 'Data IN from GPS
    arrayread gprmc,[DEC2 hh,DEC2 mm,dec2 ss,_
      wait(","),fix,wait(","),DEC2 latdeg,DEC2 latmin,wait("."),dec4 latminn,_
      wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait("."),dec4 lonminn,_
      wait(","),EW,wait(","),dec knots,dec Knotss,dec course,_
      wait(","),DEC2 dy,DEC2 mt,DEC2 yr]      'parse the GPS array into parts
    'high xpwr
    if fix = "V" then nofix  'jump to "waiting for fix" display
    SEROUT2 xbtx,188,[$0D,$0A,"$GPRMC,",STR GPRMC\63]            'Data OUT to XBEE
    'low xpwr
    pause 5000
    'gosub calcmph  'convert knots.knotss to mph.h
    'serout2 lcd,16780,[i,h," ",dec2 latdeg,$DF,dec2 latmin,".",dec4 latminn,"'",ns,dec2 mph,dec1 mphh]
    'serout2 lcd,16780,[i,line2,dec3 londeg,$DF,dec2 lonmin,".",dec4 lonminn,"'",ew,dec3 course]
    '-----------subroutines-------------------------
    'CalcMPH:
    '  arraywrite speed,[dec2 knots,dec2 knotss] 'combine knots and knotss into 4 byte array
    '  arrayread speed,[dec4 kk]                 'now get the 4 digit dec value of the array
    '  mph  = kk * 9881
    '  mph  = R0 + R2.15 + kk 'mph now contains 4 digit value of mph/tenths/hundredths
    '  mphh = mph//100      'isolate tenths and hundredths
    '  mphh = mphh/10       'eliminate the hundreths and keep tenths
    '  mph = mph/100        'now keep integer mph, first two digits of 4 digit value
    'return
    NoFix:
      serout2 xbtx,188,["waiting for fix"]
    tmout:   'end up here if no data from gps within 3 seconds
      serout2 xbtx,188,["timeout"]
      GOTO MAIN
    Last edited by Heckler; - 9th March 2011 at 17:12. Reason: extra information added
    Dwight
    May 2008
    Italy
    Is there a way to define LEDXs' TRISIO and GPIO and then call LEDX. It would make the repeated use of individual LEDs alot easier.
    Not just as you wrote it, but you can semplify this way:
    LED_T_1 VAR BYTE
    LED_G_1 VAR BYTE
    LED_T_2 VAR BYTE
    LED_G_2 VAR BYTE
    LED_T_1 = %00011110
    LED_G_1 = %00000001
    LED_T_2 = %00011110
    LED_G_2 = %00100000
    TRISIO = LED_T_1
      GPIO = LED_G_1
    TRISIO = LED_T_2
      GPIO = LED_G_2
    Now since you don,t need to change the TRISIO then you can write:
    LED_G_1 VAR BYTE
    LED_G_2 VAR BYTE
    TRISIO = %00011110
    LED_G_1 = %00000001
    LED_G_2 = %00100000
    GPIO = LED_G_1
    GPIO = LED_G_2
    .. or in a normal way you can write:
    LED1 VAR GPIO.0
    LED2 VAR GPIO.6
    TRISIO = %00011110
    LED1 = 1
    LED2 = 0
    PAUSE 500
    LED1 = 0
    LED2 = 1
    PAUSE 500
    GOTO MAIN
    .. again in a more sophisticated way:
    LED1 VAR GPIO.0
    LED2 VAR GPIO.6
    TRISIO = %00011110
    LED1 = !LED1
    LED2 = !LED1
    PAUSE 500
    GOTO MAIN
    Cheers
    Al.
    Sep 2010
    Las Vegas, NV
    Hey, thanks for the reply and for showing the progression from functional to elegant. But would you mind verifying my logic?
    Since I'm an unsophisticated person, I want to make sure I understand what's going on in the following snippet. Variables get declared, TRIS set and then LED1= !LED1 sets a 1, because its prior value was 0, turning on LED1. LED2= ! LED1 turns off LED2 because it's value is set to 1 in the previouse line. Then it loops and the !LED1 keeps toggling the state of LED1 and LED2.
    Is that close? Is it necessary to set the gpio.0 or gpio.6 to 0 to make sure they turn off at start up?
    LED1 VAR GPIO.0
    LED2 VAR GPIO.6
    TRISIO = %00011110
    LED1 = !LED1
    LED2 = !LED1
    PAUSE 500
    GOTO MAIN
    Cheers
    Al.[/QUOTE]
    May 2008
    Italy
    Is that close?
    You have got it!
    No, since Led1 and Led2 has been declared as alias of gpio.0 and gpio.6. So if you want set them to zero just state Led1=0 : Led2=0.
    Cheers
    Al.
    Oct 2009
    Utah, USA
    Also... don't overlook the fact that GPIO.3 can only be an INPUT. It defaults to MCLR or "Master Clear with internal pull-up". This means it will reset the chip whenever it goes low.
    In order to make it a normal input pin you MUST change the "Configuration Word Register" bit 5. This register can ONLY be defined once at the time of programming. I think some refer to it as the "FUSE bits" or "configuration fuses" This special register can only be changed each time you program the chip and is not change-able during runtime of your program.
    I think I lost a few hairs and much sleep trying to understand the details of configuring PIC's and the registers. I now keep the .pdf of what ever chip I am working with open and refer to it often as I am defining the functionality of my chip and the various I/O pins, analog, comparators, pulse width modulation, etc, etc.
    I hope this helps and is not too basic for your level.
    In the beginning I tried to use GPIO.3 as a normal input and could not for the life of me figure out why it kept resetting my program...
    regards
    Dwight
