PIC18F4850 will not oscillate
Results 1 to 25 of 25
    Mar 2011
    Default Re: PIC18F4850 will not oscillate
    Bruce,
    I read back the configuration from the PIC, and it returned the following:
    0000- 0200 1f17 8200 0081 c00f e00f 400f
    Towards the bottom of the window, it has a 0xEB87. I can't really tell what this data means, so I am looking at the DS39622L document from microchip. But I really can't see how those two relate. Page 29, of the document shows the configuration bits and the CONFIG1H is located at 300001h.
    Mark_s,
    I changed the 18F4580.INC file to comment out the _CONFIG statements and recompiled. I also change the options to the meProg to not "Update configuration from file". I reprogrammed the device, but no luck. I read back the configurations bits and they are the same as above.
    Any more ideas?
    Mar 2011
    So I made sense of the configuration read back results. And as I imagine the CONFIG1H is not being set by the U2 programmer.
    CONFIG1H = 02 (HS Oscillator enabled)
    CONFIG1L = 00 (default))
    CONFIG2H = 1F
    CONFIG2L = 17
    CONFIG3H = 82
    CONFIG3L = 00
    CONFIG4H = 00
    CONFIG4L = 81
    CONFIG5H = C0
    CONFIG5L = 0F
    CONFIG6H = E0
    CONFIG6L = 0F
    CONFIG7H = 40
    CONFIG7L = 0F
    The configuration file seems to be correct. Can anyone make sense of what is going on?. I have two cards behaving exatly the same.
    Last edited by IRQ_Diode; - 9th March 2011 at 01:06. Reason: Corrected the H and L on the CONFIGx table.
    When you read the .HEX from the PIC with your programmer, just click the C to view the config settings embedded in the .HEX file. Like you did in post #4.
    If it reads back with the settings you expect, then I would have to suspect a bad oscillator, caps, or something in the external osc circuit causing a problem.
    Double check those SMD caps to make sure they're not resistors...;o)
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2010
    USA, New England
    Is "Options|Update Configuration From File" checked? It shouldn't be.
    Best Regards,
    Paul
    Mar 2011
    I read the configuration back from the PIC and it reads the correct settings for the oscillator
    I have open a ticket with Microchip and contacted melabs to see if they have another idea on how to get this solved. I have tried two different oscillators.
    Has anyone used a PIC18F4580 that could let me know what oscillator they used (actual part number)?
    Last edited by IRQ_Diode; - 9th March 2011 at 07:12. Reason: fixed PIC part number
    Add this to your config settings just below your _CONFIG2H line;
    __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOREN_BOHW_2L & _BORV_3_2L
    This should give it more time for the oscillator to start up.
    -Bruce
    tech at rentron.com
    Mar 2011
    Bruce,
    I did try your suggestion and added the line:
    The programmer read the configurations bits correctly, but the PIC still will not oscillate. I also went and checked the caps just to make sure that they were not resistors, and well they were not.
    I am considering that it could be the actual part number of the crystal itself. The only thing I have not tried is to place a series resistor to one side of the oscillator. I would have to cut the trace and make sure that I do not short anything to the ground pour around the oscillator.
    So before I do that, is there anything else someone can think of? Microchip is taking its time to respond, and I need to send the gerber files to the manufacturer soon.
    IRQ
