PIC18F4850 will not oscillate
Results 1 to 25 of 25
Threaded View
  1. #8
    Default Re: PIC18F4850 will not oscillate
    Your config settings look good(screen shot). The U2 program has a pull down menu option which allows you to select between using the configs written in your code or from the config menu on the programmer. Try changing this setting and commenting your configs out of your code.
