PIC18F4850 will not oscillate
Results 1 to 25 of 25
    Mar 2011
    Default PIC18F4850 will not oscillate
    I have board that I can program using the U2 (USB) Programmer from melabs. I have a blink program that works well when I pick the internal oscillator (at 8Mhz). I have designed the card to use a 20MHz external oscillator but I have not been able to make it work. I just bought the programmer not too long ago, and I am able to program the device as long as I use the internal oscillator.
    When I change the settings to HS on the meprog software, the board will not work and the oscillator will not oscillate (checked with a 10x probe). The design uses a 20Mhz oscillator (PN: ECS-200-20-5PXDU-TR, see attached schematic) and 20pF loading caps. The board layout is exactly as what has been recommended on the PIC datasheet. The only lines from the programmer to the card are GND, PGC, PGD, and my card has a 100K pull down on PGM. I have change the oscillator to another can oscillator I used on another circuit, but it still the new design does not work. During programming I am using the internal power supply which I checked an it is 4.98V. So I tried using the programmers Pin1 5V to power my board but that did not work either. I have also tried the @confiure..... but no luck neither.
    I believe that somehow the fuses for external oscillator do not set properly and the oscillator does not oscillate. I have changed, oscillators, placed different loading caps, put a 1M across the oscillato, removed the laoding caps, but no luck so far. I am only able to run the board with internal OSC set up. I read on another thread that someone used the Vdd (Pin 4) on the USB programmer to power the board during programming and it worked. Nevertheless your website does explicitly said not to use the Vdd pin 4 as it is used for powering adaptors and not ICSP.
    I would really appreciate if anyone can point me in the right direction, as I have tried everything and I have not been able to make the external oscillator to work. I believe I am having an issue with the programming of the HS fuse, but I just have not been able to make it work with the PIC18F4580. I am always setting up the HS with the programmer.
    I have never had issues with oscillators not working, but somehow this one doesnt. By the way I have 2 board populated and they behave exactly the same, with and without the same oscillators.
    Thank you,
    Default Re: PIC18F4850 will not oscillate
    Try setting the configs in the *.inc file found in the PBP directory.
    Hello,
    You also need to have the MCLR connected to the U2 programer. I did not see it connected in your schematic or discription? Set the config to "HS" and it should work.
    I am sure you have seen this page
    http://melabs.com/support/icsp.htm
    Power your circuit with an external 5v supply
    connect U2 with GND, PGD, PGC and VPP(mclr) to the PIC
    Mar 2011
    Mark,
    Although not completle shown on the schematic I posted, the MCLR is pulled-up with a resistor and a diode, and it also goes to the U2 Programmer. I have also set the meprog to HS as show in the attached picture.
    Mackrackit,
    The PIC18F4850.INC (file which is in the include statement of my *.asm) is as follows and it too sets up the oscillator to HS
    ;*  18F4580.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2008 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 09/15/08                                        *
    ;*  Version   : 2.60                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F4580, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F4580.INC"	; MPASM  Header
            __CONFIG    _CONFIG1H, _OSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
            __CONFIG    _CONFIG4L,  _STVREN_ON_4L & _LVP_OFF_4L & _BBSIZ_1024_4L & _XINST_OFF_4L
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	8
    Are you picking the correct PIC?
    Take a look at the inc you posted...
    Mar 2011
    Dave,
    Good catch and it got me excited for a second there, but I just noticed that I have a typo on my thread title.
    The PIC I have is the 18F4580, there is not such a thing as a PIC4850. I might be dislexic . THe file I posted is the correct one, so is the decription of the PIC on the schematic I posted.
    Any other ideas? I am setting the "Fail-safe clock monitor" and "Internal External Switch over" options so the PIC can run from the internal oscillator while I get this external oscillator to work. But I have tried it all, so any fresh input from anyone, will really help.
