Using 18F4525 with PortA defined as all inputs - RA2 and RA3 always show logic 0
Results 1 to 5 of 5
    Mar 2011
    Default Using 18F4525 with PortA defined as all inputs - RA2 and RA3 always show logic 0
    I am using an 18F4525 and I would like to use PortA as inputs. I am using an external osc, so pins RA6 and RA7 are allocated for that function. I have configured PortA to be all inputs, but when I read the port with logic 1 on the inputs, RA2 and RA3 always show 0. Can someone point out what I am doing wrong? Thank you.
    porta = %00000000
    adcon1 = %11111111 ' PortA - Set to digital
    cmcon = %00000111 ' Disable Comparators
    trisa = %11111111 ' PortA - All Inputs
    trisb = %00000000 ' PortB - All Outputs
    statusloop: portb = porta
    goto statusloop
    I have LEDs on all PortB pins and bits 0, 1, 4, & 5 follow the logic placed on the corresponding PortA pins. Bits 2 and 3 always show 0.
    Aug 2010
    Maryland, USA
    Default Re: Using 18F4525 with PortA defined as all inputs - RA2 and RA3 always show logic 0
    maybe this is the problem?:
    Note: On a Power-on Reset, RB4:RB0 are
    configured as analog inputs by default and
    read as ‘0’; RB7:RB5 are configured as
    digital inputs.
    By programming the Configuration bit,
    PBADEN, RB4:RB0 will alternatively be
    configured as digital inputs on POR.
    -Bert
    Mar 2011
    In my full program I flash all of the LEDs on PortB to show that PortB is working correctly and they do all flash as I would expect them to. I believe that it is something with the configuration of PortA, but I don't know what! Thank you.
    Try adcon1 = %00001111. With adcon1 = %11111111 you have RA2 and RA3 set for Vref- & Vref+.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2010
    Maryland, USA
    I doubt this is it, but can you try it with
    adcon1 = %11001111
    -Bert
