Now THAT is a good idea! I'll have to play with that in particular application and see how it works.
Thanks!
Thanks!
Agreed that is a good idea. can you post your code example when tested.
I'll do the same If i get round to it first
OK so assuming i set up HSERIN/OUT for 9 bit even parity
I do my 9 bit recieve then just before I want to do my 8bit transmit i clear the TXSTA TX9 flag
Just a thought though if we clear the TXSTA TX9 flag just before we do the HSEROUt won't it just overwrite it immediately?
Is the TXSTA only loaded once during program execution when the define is executed? I appreciate the parity bit is changed to suit.
Or am I confused.
Hmmm, good point. I was/am assuming PBP sets and forgets it. setting it on each transmission seems like wasted code.
-Bert
I'm going to try
See if that works as clearing the 9 bit mode bit for the txd should hopefullyCode:DEFINE HSER_BAUD 9600 'Set Baud rate to 9600bps DEFINE HSER_BITS 9 'Set to 9 bit mode DEFINE HSER_EVEN 1 'Set Even Parity DEFINE HSER_CLROERR 1 'Clear overflow error automatically TXSTA.6 = 0 'Clear 9 Bit Txd Mode
leave the rxd unaffected and in 9 bit mode.
Perhaps we can ask the pbpro author to support seperate defines for rxd and txd ausart.
This seem to work OK!
So I am receiving my 9600,8,E,1 data on Usart RXD Hserin
and
I am driving my lcd display using Usart TXD at 9600,8,N,1 Hserout
Defines as above in my previous post for parity
I just cleared the 9 bit register TXSTA.6 once at start of program after defines and seems to work fine!!
Thanks for all the ideas.
I've just tried this at my end and it seems to work fine. The DEFINE sets the RCSTA and TXSTA (once) as well as "tells" the compiler to insert code to calculate the parity bit for each byte it send and receives. If we then "override" and disables the transmision of the 9th bit PBP will still calculate and load that bit into the 9th databit "slot" but it will never get sent out.
In my particular case I'm swiching between using and not using parity for both RX and TX, at runtime, so I had to add dual HSERIN commands in my receive ISR, like:Thanks again for pointing this, now pretty obvious, way out!Code:If RCSTA.6 = 1 THEN 'If 9th bit reception is enabled we're using parity. HSERIN ParityError, [RxChar] ELSE HSERIN [RxChar] ENDIF Goto OverParityError ParityError: 'Handle it here OverParityError: 'Continue here....
Ha, talk about coincidence, posting pretty much the same thing at the same time like that. I didn't see your post before writing mine. It's great that you got it working at your end as well!
