accurate vref < 1vdc 16F876 comparator
Results 1 to 2 of 2
    mslaney's Avatar
    mslaney Guest
    Default accurate vref < 1vdc 16F876 comparator
    Hi there,
    I'm trying to do the groundwork on using the comparator in the F876 but I can't seem to find the internal resistor values for the chip in the datasheet.
    I'm probably missing something but I thought I could get some additional input from the forum as well.
    I need a low or a high sig based on the input voltage to the comparator. The trigger voltage is going to be around 0.8vdc, maybe lower. Will I get more accurate results with an external vref as opposed to the internal vref?
    What about the deadband of the internal comparator? Has anybody noticed a significant amount of chatter when the signal approaches the threshold v?
    How do I set the threshold voltage(s) in PICBasic Pro?
    mslaney's Avatar
    mslaney Guest
    I found this in another search in case you were/are in the same spot as me but were afraid to ask.... ;-)
    http://list.picbasic.com/forum/messa...tml?#POST13269
    Thanks melanie
  1. 18F2525 A/D, Comparator and Vref modules
    By fbraun in forum mel PIC BASIC Pro
    Last Post: - 21st May 2005, 00:17
