DC LED Dimming on 3-5 channels using 16F676
Results 1 to 3 of 3
    Exclamation DC LED Dimming on 3-5 channels using 16F676
    I need some help in making a program which can generate pwm on 3-5 pins. These pins will be connected to MOSFETS and they will in turn control a bunch of LEDs.
    Is it possible to have a different duty cycle on each pin? I would create it in such a way that once PIC is powered up all 3 or 5 channels have different dutycycles and thus the bunch of LEDs glow at different intensities which keep changing in a loop.
    I would like to achieve this with 16F676. I have 12V battery available which will be the power source for the system.
    Any ideas?
    Thanks in advance
    ___________________
    WHY things get boring when they work just fine?
    Default Re: DC LED Dimming on 3-5 channels using 16F676
    Give this a try ...
    MIBAM - (Mirror Imaged Bit Angle Modulation)
    http://www.picbasic.co.uk/forum/showthread.php?t=10564
    Jan 2006
    Istanbul
    Also, take a look at this one to get some ideas.
    <font color="#000000">Begin:
    <font color="#000080"><i>' Change these values as desired.
        </i></font>RED   = <font color="#FF0000">100 </font><font color="#000080"><i>' Red intensity
        </i></font>GREEN = <font color="#FF0000">150 </font><font color="#000080"><i>' Green intensity
        </i></font>BLUE  = <font color="#FF0000">200 </font><font color="#000080"><i>' Blue intensity
    ' ===== Drive LEDs ===========
        </i><b>PWM </b></font>RedPin,RED,<font color="#FF0000">1
        </font><font color="#000080"><b>PWM </b></font>BluePin,BLUE,<font color="#FF0000">1
        </font><font color="#000080"><b>PWM </b></font>GreenPin,GREEN,<font color="#FF0000">1
        </font><font color="#000080"><b>GOTO </b></font>Begin
