Early Feb has come and gone
Results 1 to 14 of 14
    Default Re: Early Feb has come and gone
    Goto the MPASM SUITE directory under C:\Program Files\Microchip\MPASM Suite
    There you will find MicroChips *.inc file for the chip. At the end of the file all of the configs are listed.
    I did not see what you are planning to use for an OSC. Post a little bit more about your setup, MCLR and stuff and we can help with the configs.
    Mar 2005
    Cocoa, Florida
    Dave, thanks for coming back.
    My setup is whatever someone else has working. Don't care about CPU speed for now.
    The program works fine on 16Fxxx.
    I've tried 4, 8 and 20meg crystals/resonators, changed divider in INC and set DEFINE OSC n to clock speed.
    Currently 4 divided by 1.
    All result in the same low clock out as if the crystal is not doing anything.
    Tried HS and HSPLL. Have a 20MHz oscillator so will try that next using EC.
    But I suspect it's nothing to do with the clock settings (as they don't make any difference), it's another switch somewhere.
    'setup:
    ' @ __CONFIG _CONFIG1H _HSPLL_OSC_1H
    ' @ __CONFIG _CONFIG1H _XINST = OFF
    ' @ __CONFIG _CONFIG1H _PLLDIV = 5
    ' @ __CONFIG _CONFIG1H _WDTPS = 512
    ' @ __CONFIG _CONFIG1H _ADCSEL = BIT12
    DEFINE OSC 4 ' set the clock speed
    DEFINE DEBUG_REG PORTC ' Set Debug pin port
    DEFINE DEBUG_BIT 2 ' Set Debug pin bit
    DEFINE DEBUG_BAUD 9600 ' Set Debug baud rate
    DEFINE DEBUG_MODE 1 ' Set Debug mode: 0=true (for drivers), 1=inverted
    DEFINE LCD_LINES 4 ' Using a 4 lines LCD
    ; Oscillator:
    ; OSC = INTOSC INTOSC
    ; OSC = INTOSCO INTOSCO (CLKO-RA6)
    ; OSC = INTOSCPLL INTOSCPLL
    ; OSC = INTOSCPLLO INTOSCPLLO (CLKO-RA6)
    ; OSC = HS HS, USB-HS
    ; OSC = HSPLL HS+PLL, USB-HS+PLL
    ; OSC = EC EC (CLKO-RA6), USB-EC
    ; OSC = ECPLL EC+PLL (CLKO-RA6), USB-EC+PLL
    ; PLL Prescaler Selection:
    ; PLLDIV = 12 Divide by 12 (48 MHz oscillator input)
    ; PLLDIV = 10 Divide by 10 (40 MHz oscillator input)
    ; PLLDIV = 6 Divide by 6 (24 MHz oscillator input)
    ; PLLDIV = 5 Divide by 5 (20 MHz oscillator input)
    ; PLLDIV = 4 Divide by 4 (16 MHz oscillator input)
    ; PLLDIV = 3 Divide by 3 (12 MHz oscillator input)
    ; PLLDIV = 2 Divide by 2 (8 MHz oscillator input)
    ; PLLDIV = 1 No prescale (4 MHz oscillator input drives PLL directly)
    I do not have that chip to actually test this, but try this using the internal OSC.
    'Set the *.inc OSC configs to..
    CONFIG PLLDIV = 2
    CONFIG OSC = INTOSCPLL
    CPUDIV = OSC1
    Then in your code
    DEFINE OSC 48
    That should have the chip set to run at USB speeds using the built in OSC.
    Mar 2005
    Cocoa, Florida
    Thanks Dave.
    Tried INTOSCPLL and INTOSCPLLO
    Whatever I do produces 1 meg clock out.
    Going to order some more and see if I've blown up this guy
    Let you know...
    LIST
    LIST p = 18F27J53, r = dec, w = -311, f = inhx32
    INCLUDE "P18F27J53.INC" ; MPASM Header
    CONFIG XINST = OFF
    CONFIG WDTPS = 512
    CONFIG PLLDIV = 2 ; CONFIG PLLDIV = 5
    CONFIG OSC = INTOSCPLLO ; CONFIG OSC = HSPLL
    CPUDIV = OSC1
    CONFIG ADCSEL = BIT12
    NOLIST
    Aug 2010
    Maryland, USA
    Check the OSCTUNE.6 bit. It may need to be set to actually turn on the PLL
    -Bert
