Problems with 16F684
Results 1 to 27 of 27
    Dec 2008
    Ploiesti, ROMANIA
    Default Problems with 16F684
    I try to build one thermo-volt-meter for using in my car. I wrote the code, based on my (working) previous experiences with DS18B20 and the great example of Mr.Gioppy (SerVolt). But...the result are ...strange : despite Ubat = 16 Volts, on display the value is 0.02, alternating with 0.22 ?!?
    Maybe a sharp mind will find my mistake(s). Thanks in advance !!!
    ; http://www.picbasic.co.uk/forum/showthread.php?t=7182&highlight=gioppy
    ; Volt-termometru cu 16F676
    @ DEVICE pic16F684, intrc_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
    define osc 4
    TRISA= %00010000
    TRISC= %00110000
    CMCON0  = %00000111      'Disable analog comparators.
    DEFINE ADC_BITS 10       ' 10 bit A/D Conversion
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50   ' 50 uS A/D sample time
    VRCON  = %00000000       ' Disable Comparator Voltage Reference
    ANSEL  = %00000100       ' Set pin (AN2) to analog input, the rest to digital
    ADCON0 = %10001001       ' Set up A/D converter - Right Just., VDD REF., CH 2, ON
    ADCON1 = %00110000       ' Set up A/D Converter clock source to internal RC
    DEFINE LCD_DREG PORTC                      ' LCD on port B
    DEFINE LCD_DBIT 0                          ' Data bits B4..B7
    DEFINE LCD_RSREG PORTA                     ' RS on PORTA
    DEFINE LCD_RSBIT 1                         ' RS on A1
    DEFINE LCD_EREG PORTA                      ' E on PORTA
    DEFINE LCD_EBIT 0                          ' E on A0
    DEFINE LCD_BITS 4                          ' LCD 4 bit mode
    DEFINE LCD_LINES 2                         ' 2 line LCD display
    Define LCD_COMMANDUS 2000                  ' Command Delay (uS)
    Define LCD_DATAUS 50                       ' Data Delay (uS)
    Temperature1     Var    Word        ' Temperature storage
    Temperature2     Var    Word        ' Temperature storage
    TempC1           Var    Word
    TempC2           Var    Word
    Float1           Var    Word
    Float2           Var    Word
    Sign1         Var    Byte        ' +/- sign
    Sign2         Var    Byte        ' +/- sign
    DQ1         Var    PORTC.5        ' One-wire data pin
    DQ2         Var    PORTC.4        ' One-wire data pin
    Twist1           Var    Bit
    Dummy1           Var    Byte
    V1               Var    Word
    Twist2           Var    Bit
    Dummy2           Var    Byte
    V2               Var    Word
    Vfs             con     20480           '20,480v
    K16             con     61441           'coefficiente filtro 15/16
    Vbatt           var     word            'Vbatt filtrato
    TmpW            var     word
    Acc_Vbatt       var     word            'accumulatore Vbatt filtrato * 16
    DS18B20_1_12bit CON %01111111             ' 750ms,   0.0625°C  (default)
    DS18B20_2_12bit CON %01111111             ' 750ms,   0.0625°C  (default)
    Twist1 = 0
    Twist2 = 0
    Pause 500
    LCDOUT $FE, 1, $FE, $0C                 ' Clear display, cursor off
    Pause 500
    ' Init Sensor 1
     OWOUT DQ1, 1, [$CC, $4E, 0, 0, DS18B20_1_12bit]
     OWOut DQ1, 1, [$CC, $48]                   ' Start temperature conversion
     OWOut DQ1, 1, [$CC, $B8]
     OWOut DQ1, 1, [$CC, $BE]
     Pause 50
     OWIn DQ1, 2, [temperature1.byte0, temperature1.byte1]
     Pause 50
    ' Init Sensor 2
     OWOUT DQ2, 1, [$CC, $4E, 0, 0, DS18B20_2_12bit]
     OWOut DQ2, 1, [$CC, $48]                   ' Start temperature conversion
     OWOut DQ2, 1, [$CC, $B8]
     OWOut DQ2, 1, [$CC, $BE]
     Pause 50
     OWIn DQ2, 2, [temperature2.byte0, temperature2.byte1]
     Pause 50
    Main :
    Part1:
    ' Start temp.conv.Sensor1
     OWOut DQ1, 1, [$CC, $44]
     WaitLoop1:
     While not DQ1
     Wend
    If Temperature1.15 then
      Temperature1= ~Temperature1 +1
      Twist1 = 1
    Endif
    Dummy1 = 625 * Temperature1
    TempC1 = DIV32 10
    TempC1 = (Temperature1 & $7FF) >> 4
    Float1 = ((Temperature1.Lowbyte & $0F ) * 25 )>>2
    Temperature1 = TempC1*100 + Float1
    If Twist1 then
      V1= 10000 - Temperature1
      Twist1 = 0
      V1= 10000 + Temperature1
    EndIf
    If V1 >= 10000 then
      Temperature1=V1-10000
      Temperature1=10000-V1
    EndIf
    Part2 :
     OWOut DQ2, 1, [$CC, $44]
     WaitLoop2:
     While not DQ2
     Wend
    If Temperature2.15 then
      Temperature2= ~Temperature2 +1
      Twist2 = 1
    Endif
    Dummy2 = 625 * Temperature2
    TempC2 = DIV32 10
    TempC2 = (Temperature2 & $7FF) >> 4
    Float2 = ((Temperature2.Lowbyte & $0F ) * 25 )>>2
    Temperature2 = TempC2*100 + Float2
    If Twist2 then
      V2= 10000 - Temperature2
      Twist2 = 0
      V2= 10000 + Temperature2
    EndIf
    If V2 >= 10000 then
      Temperature2=V2-10000
      Temperature2=10000-V2
    EndIf
    GoSub SelectSign
    Gosub Get_Vbatt                           ' make a new measure
            TmpW = Vbatt * Vfs                    ' AD * 20480
            TmpW = Div32 1024                     '(AD * 20480) / 1024
    if (temperature1/100) =>10 then
    LcdOut $FE, $80, "I:", Sign1, DEC (Temperature1 / 100), ".", DEC Temperature1 dig 1, 223
    LcdOut $FE, $80, "I:", Sign1, $14, DEC (Temperature1 / 100), ".", DEC Temperature1 dig 1, 223
    if (temperature2/100) =>10 then
    LcdOut $FE, $c0, "O:", Sign2, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, 223, " ", "V:",dec TmpW dig 4,dec TmpW dig 3,",",dec TmpW dig 2
    LcdOut $FE, $C0, "O:", Sign2, $14, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, 223, " ", "V:", dec TmpW dig 4,dec TmpW dig 3,",",dec TmpW dig 2
    Goto Main
    SelectSign:
    If v1 = 10000 then
      Sign1=" "
      If v1 < 10000 then
       Sign1="-"
       Sign1="+"
      EndIf
    EndIf
    If v2 = 10000 then
      Sign2=" "
      If v2 < 10000 then
       Sign2="-"
       Sign2="+"
      EndIf
     EndIf
    Get_Vbatt:
            ADCON0.1 = 1                        'start A/D
            while ADCON0.1 = 1
            wend
            TmpW.byte1 = ADRESH                 'get A/D value
            TmpW.byte0 = ADRESL
            Acc_Vbatt = Acc_Vbatt ** K16 + TmpW      'filtro 15/16
            Vbatt = Acc_Vbatt / 16                  ' / 16 valore normalizzato
            Acc_Vbatt = TmpW * 16                 'filter preload  Vbatt * 16
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Problems with 16F684
    I found two errors :
    - TRISA= 000100
    - mising "else" in display "O:" temperature.
    Now display works fine, but...maximum value of Ubat is 6,44.
    LE : I did it ! RV2 changed to 5 K. The value on display it's correct now !Name:  result.jpg
    Dec 2008
    Ploiesti, ROMANIA
    I need to re-configure the I/O pin assignement, so I re-wrote the code for new hardware. In ISIS I have this problem :
    It's just one simulation problem or software problem ? Need advice ! Thanks !
    @ DEVICE pic16F684, intrc_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_OFF
    define osc 4
    TRISA= %00010000
    TRISC= %10110000
    DEFINE ADC_CLOCK 3
    ANSEL  = %10000000       ' Set pin (AN7) to analog input, the rest to digital
    ADCON0 = %10011101       ' Set up A/D converter - Right Just., VDD REF., CH 7, ON
    ;----[ Change these to match your LCD ]---------------------------------------
    LCD_DB4    VAR PORTA.2
    LCD_DB5    VAR PORTC.0
    LCD_DB6    VAR PORTC.1
    LCD_DB7    VAR PORTC.2
    LCD_RS     VAR PORTA.0
    LCD_E      VAR PORTA.1
    LCD_Lines  CON 2     ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS CON 50     ' Data delay time in us
    LCD_COMMANDUS CON 2500     ' Command delay time in us
    INCLUDE "LCD_AnyPin.pbp"
    Note : I modify pbppic14.lib like Mr.Darrel say in "LCD_Any_pin" and I have the properly .pbp in PBP directory.
    Jan 2010
    Hi!
    I made my own tacho-volt-therometer with about the same schematic:
    http://www.vandi.ro/electronics/turo...metru_auto.htm
    This page is in Romanian language but maybe you and others found it useful.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You for link ; but with (almost) similar hardware as Yours, my schematic work fine. BUT ... I intend to use another configuration for LCD pins (for optimised PCB), based on "LCD_Any_pin" ! This is my problem !
    I check many variants for these :
    LCD_Lines  CON 2                    ' changed on 1, of course !!!
    LCD_DATAUS CON 50               ' Data delay time in us -- changed to 200
    LCD_COMMANDUS CON 2500     ' Command delay time in us -- changed to 5000
    without results...
    Dec 2008
    Ploiesti, ROMANIA
    Maybe the .dsn file help to understand...
    fratello,
    Can you post your code.
    I don't get the error with your .DSN file using this code...
    define OSC 4
    TRISA= %00010000
    TRISC= %10110000
    DEFINE ADC_CLOCK 3
    LCD_DB4    VAR PORTA.2
    LCD_DB5    VAR PORTC.0
    LCD_DB6    VAR PORTC.1
    LCD_DB7    VAR PORTC.2
    LCD_RS     VAR PORTA.0
    LCD_E      VAR PORTA.1
    X VAR WORD
        X = X + 1
        LCDOUT $FE,$80,DEC X,"    "
    GOTO Main
    Dec 2008
    Ploiesti, ROMANIA
    Mr.Darrel ! THANK YOU for watching my post ! It's such a nice surprise !
    The rest of code it's in post #1 ; just the parts concerning 16F684 and "LCD_AnyPin" it's changed...
    I don't get any errors with the code from post#1.
    Well, at least not with the LCD.
    I think you still have some problems in the code working with the DS18B20 though.
    Dec 2008
    Ploiesti, ROMANIA
    It's strange ! Using hardware and code from post #1 (and #2) the things are OK, in Proteus and "in vivo" ; changing just the configuration of LCD pins the schematic dont work anymore...I will try to build the schematic and see what happens
    Dec 2008
    Ploiesti, ROMANIA
    Simple schematic, simple code, WITHOUT DS18B20 ...Still no result !!! I am ...
    define osc 4
    TRISA= %00000000
    TRISC= %00001000
    DEFINE ADC_CLOCK 3
    LCD_DB4    VAR PORTA.2
    LCD_DB5    VAR PORTC.0
    LCD_DB6    VAR PORTC.1
    LCD_DB7    VAR PORTC.2
    LCD_RS     VAR PORTA.0
    LCD_E      VAR PORTA.1
    LCD_Lines  CON 1     ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_COMMANDUS CON 2000     ' Command delay time in us
    TmpW            var     word
    Pause 500
    Pause 500
    Main :
            while ADCON0.1 = 1
            wend
            TmpW.byte0 = ADRESL
    LcdOut $FE, $c0, dec TmpW dig 4,dec TmpW dig 3,",",dec TmpW dig 2
    Goto Main
    Dec 2008
    Ploiesti, ROMANIA
    Same weird behavior using JUST code for thermometer ...
    Main :
      Twist1 = 1
    Endif
    TempC1 = DIV32 10
    If Twist1 then
      Twist1 = 0
    EndIf
    If V1 >= 10000 then
    EndIf
    GoSub SelectSign
    Goto Main
    SelectSign:
    If v1 = 10000 then
      Sign1=" "
      If v1 < 10000 then
       Sign1="-"
       Sign1="+"
      EndIf
    EndIf
    Dec 2008
    Ploiesti, ROMANIA
    Sorry for pollute this great forum ... I think it's a PROTEUS error ; with the code posted by Mr.Darrel I have the same messages .Name:  code_Mr_Darell.jpg
    Dec 2008
    Ploiesti, ROMANIA
    Bad news, for me ... The hardware DON'T WORK ! Just some stranges characters appears on display, not stable-fast changing ...cannot post pictures... I try even code of Mr.Darrel (posted above). I think it's a "incompatibility" between THIS PIC and "LCD_AnyPin" ?!?
    What else I cand do (outside of using "clasic" configuration of LCD-PIC pins) ?
    Dec 2008
    Ploiesti, ROMANIA
    Please, can someone to compile this file for me ? Maybe it's something wrong with my PBP or WinXp or...I dont know....
    Thanks in advance !
    Mar 2009
    Colorado
    Quote Originally Posted by fratello View Post
    Thanks in advance !
    I would be willing to compile your code with my PBP v. 2.6 compiler, and I tried to do so. But it won't compile without the include file "LCD_AnyPin.pbp" . If you can post the code to this include file I will give it a go for you.
    Regards, jellis00
    Dec 2008
    Ploiesti, ROMANIA
    Thank You for help ! Mr.Darrel code can be found there : http://www.picbasic.co.uk/forum/cont...CD-on-any-pins
    Mar 2009
    Colorado
    Sorry, fratello....I thought I could help you but I found out your code is setup for use only with the PM assembler which I can't use with my 64 bit machine. I can only use the MPASM assembler. Maybe someone else can help you test compile this.
    Dec 2008
    Ploiesti, ROMANIA
    Never mind...Thanks anyway for help !
    Regards !
    Jan 2010
    Hi fratello!
    I tried to compile but I got :
    Error UNTEST~.ASM 440: [235] opcode expected insted of 'error'
    Dec 2008
    Ploiesti, ROMANIA
    Strange ...
    I have no errors on compiling...just not work !
    Dec 2008
    Ploiesti, ROMANIA
    With code from post #1, I build this thermo-voltmeter for using in car.
    Note : for "I(nside)" I dont have anymore DS18B20 sensor...
    Jan 2010
    Congratulation, Fratello!
    Good work.
    Hi, Fratello
    I just think ISIS doesn't appreciate you do not wait for DS1820 temp conversion complete to continue running your code ...
    not a real problem ( Mikroelektronika lets it as-is in its onewire drivers ... booooo )
    in easy words, ....Change
    Main :
    for
     OWOut DQ1, 1, [$CC, $44 ]
    ' Check for still busy converting
    waitloop:
     OWIn DQ1, 4, [Busy]        ' Check for still busy converting
     Pause 95         ' Slow Down to actual Conv. time
     If NOT Busy Then waitloop
    ' Read the temperature
     OWOut DQ1, 1, [$CC, $BE ]
    you will display the very last correct measurement and not get " 85°C" or junk at power up ...
    Dec 2008
    Ploiesti, ROMANIA
    Thank You so much for help !
    I give up to use "LCD_AnyPin" ... since don't work (see post above, #14) ! I use "classic" hardware, with good results ! And I made one good PCB too...
    Best regards !
    Jan 2010
    You made that PCB in Proteus?
    Dec 2008
    Ploiesti, ROMANIA
    Oh, no ! In SprintLayout !
