Mystery instability of 16f628a
Results 1 to 19 of 19
    Default Re: Mystery instability of 16f628a
    CMCON = 7 will disable the comparators. Also place a small 0.1 or 0.01uF cap between the PIC gnd & vcc pins. Make sure it's as close as possible to the pins.
    It's also a good idea to include at least the minimum config options in your code so you're not left with whatever the default unprogrammed config bits are.
    I would use at least @ device pic16F628A, intrc_osc_noclkout, wdt_on, mclr_on, lvp_off, protect_off.
    If that doesn't take care of it, check your power supply.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    yup..my mistake...its cmcon = 7...
    Dec 2009
    Thanks for the suggestions folks. tried them all one by one and got nowhere, then noticed that /MCLR was checked in PicKit 2. Unchecked it and everything worked like a dream ! I then worked backward taking each mod off in turn to see which one had done the trick! Yes, youve guessed it .. the dam thing still worked. I have reintroduced all suggestions again in the hope that this thing shows a tad more reliability, but I'm not holding my breath !
    Thanks again
    David
    Glad to hear you got it working, but you really do want to include that cap between the gnd & vcc pis. Without it you might have more problems down the road. Some older PIC types could get by without this cap, but most all newer A versions will experience problems without it. Just FYI. It's cheap insurance...
    -Bruce
    tech at rentron.com
    Dec 2009
    Thanks Bruce. It's back in even as we speak ! Belt, braces and a piece od string as they say !
    Cheers
    Hello Davidmarks,
    I am curious, are you getting any warnings when you compile? It occurs to me, without the present ability to check MY pbp due to a hard drive failure here at home, What is the default OSC setting in the 16F628A.inc file? Have you opened it and commented it out ? Because if not, your program will use the default osc setting and NOT the one you wrote into your code. So if the default is for using a crystal instead of INTRC_OSC * * * you will in effect have the external crystal ports open to the ether looking for a finger to help start the oscillator by stray capacitance. One more thing, is the " [ " at the beginning of the config statement, in you code or just in your post?
    Dec 2009
    Thanks Joe. As I said in previous post the thing is working OK now. Didn't know about the need to change the inc file for the internal oscillator, but I have now done so and relieved to find it still works. The [ symbol was intended to signify the start of the code.. seem to remember someone telling me that I should do that when posting code. I now have yet another seemingly inexplicable problem. I am programming in circuit with PicKit 2 which has suddenly decided to stop the circuit working if I disconnect it. I have a seperate power supply which is powering the circuit so simply cannot understand why it should stop working when I remove the PicKit2 . It wasn't doing it earlier this week so I am at a loss to know what I have done ( nevertheless I'm pretty sure that I know who is to blame again!)
    Cheers
    David M
