Mystery instability of 16f628a
Results 1 to 19 of 19
    Apr 2009
    Default Re: Mystery instability of 16f628a
    add a 4.7k pull up resistor on mclr pin
    Have I gone mad
    Quite possibly - but we will hold-off sending the guys with the white coat over until we've seen schematics and code...
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2009
    Thanks for that Bruce - I should have asked matron to check my post - forgot to attach the code, Just arrived back from the village pub and tried Joseph's 4.7k pull up on mclr and lo and behold... it works ! many thanks for that .
    Cheers David
    Dec 2009
    I do not believe this ! After a spot of tinkering and adding to the circuit this am it has suddenly gone unstable again (It only operates when finger approaches or touches PIC) stripped circuit down to basic (schematic attached) and it still doesn't work. By the time i have finished it would be quicker to build the thing with valves (tubes) I used to understand them ! The code is as follows:
    [@ device pic16f628a,INTRC_OSC_NOCLKOUT
    define osc 4
    begin:
    low porta.0 ' Turn LED on
    PAUSE 500 ' Wait 500mS (1/2 second)
    high porta.0 ' Turn LED off
    GOTO BEGIN ' Loop continuously
    Have you try turning off the analog comparators? if you dont know how just add ADCON1=7 near the top row...
    Miami, Florida USA
    Also, add the line
    TRISA = 0
    Anonymous
    CMCON = 7 will disable the comparators. Also place a small 0.1 or 0.01uF cap between the PIC gnd & vcc pins. Make sure it's as close as possible to the pins.
    It's also a good idea to include at least the minimum config options in your code so you're not left with whatever the default unprogrammed config bits are.
    I would use at least @ device pic16F628A, intrc_osc_noclkout, wdt_on, mclr_on, lvp_off, protect_off.
    If that doesn't take care of it, check your power supply.
    -Bruce
    tech at rentron.com
    yup..my mistake...its cmcon = 7...
