Mystery instability of 16f628a
Results 1 to 19 of 19
    Default Re: Mystery instability of 16f628a
    Microchip sells demo boards at a reasonable price which simply plug into the pickit2. I like them for testing code snippets, easy quick push button changes and viola it is running again, no wires to fuss with. different boards for the 628 and similar vs 690 series. As for who is to blame . . . blame it on the curve, the learning curve, we ALL have lost it on that curve, be careful not to oversteer, so as not to spin out
    I am programming in circuit with PicKit 2 which has suddenly decided to stop the circuit working if I disconnect it.
    Sounds like a MCLR issue. Try _MCLRE_OFF
    in your configs.
    Dec 2006
    Brasil, Sao Paulo, Campinas
    Lightbulb Re: Mystery instability of 16f628a
    Put a 100nF capacitor near pins 5 and 14 (gnd and vcc) !
    Its solve my mistery problems in the pass.
    Good luck
    Pimentel
    Dec 2008
    New York US
    I had problem with 16f628a
    After repeating to reprogram IC with the same code it start working as has to be.
    Possible disadvantage of 16f628a is some bits of reprogrammed memory do not change their state during programming.
    Hope it helps.
    hardcore
    New Zealand
    Hi David,
    I had exactly the same problem as you seem to be having with a project I'm currently working on, also with a PIC16F628a.
    I found the answer to be _LVP_OFF
    What would happen is it defaults to LVP on, each time it would get a signal on the LVP pin, the micro would reset, hope this helps
