12F683 Startup
Results 1 to 5 of 5
Thread: 12F683 Startup
    GregK's Avatar
    GregK Guest
    Default 12F683 Startup
    Hi
    When powering up the Pic the outputs are high, when I set them as outputs and low. When I ground an input pin, the loop works fine. Please tell me what I am doing wrong.
    Set registers for all digital I/O:
    ANSEL = 0
    CMCONO =7
    ADCON0 = 7
    VRON = 0.
    TRISIO = %00111000 'Set all pins as outputs except 3.4.5
    'Inputs:
    ExtendIn var gpio.4
    RetractIn var gpio.5
    'Outputs:
    ExtendOut var gpio.0
    Low ExtendOut
    RetractOut var gpio.1
    Low RetractOut
    Loop:
    If ExtendIn = 0 then
    High ExtendOut
    Pause 2000
    Low ExtendOut
    Endif
    If RetractIn = 0 then
    High RetractOut
    Pause 2000
    Low RetractOut
    Endif
    Goto Loop
    My output's are just LED's with 1K ohm series resistors. The LED's are connected so a high pin lites the Led. I have read the data sheets and I'm still not sure about the register settings. I am using Pic Basic Pro 2.45.
    Any help or suggestions would be greatly appreciated.
    Greg
    Feb 2004
    Germany
    Greg,
    looks like your program works as designed.
    If you leave the inputs floating they will be read HIGH, so your loop doesn't do anything else than looping.
    regards
    Ralph
    GregK's Avatar
    GregK Guest
    Hi Ralph,
    Thanks for your reply.
    Let me explain a little more about the problem. The "Loop" is just to debug a problem I am having when I first power up the pic. The two input pins used in the program are pulled up through 10K resis. The third input pin (gpio.3) is always an input, and internally pulled up.
    The problem I don't understand is why both LED's are ON when I first power up the pic, with no input pins grounded. I set the outputs Low before the "Loop" and yet they are High when I power the Pic up. I have tried other 12F683's with the same results.
    Greg
    See if this configuration works for you. Note - you won't need the external pull-ups.
    @ device pic12f683, fcmen_off, ieso_off, intrc_osc, wdt_off
    @ device pic12f683, pwrt_on, mclr_off, protect_off
    GPIO = %00000000 ' All outputs low
    CMCON0=7         ' Comparators off
    ANSEL=0          ' All digital
    TRISIO=%00111000 ' Setup ins & outs
    WPU=%00110000    ' Pull-ups on for GPIO.4 & 5 inputs
    OPTION_REG.7=0   ' Enable internal pull-ups
    The default PBP header file for this device doesn't call-out the power-up timer (PWRT), so it defaults to off. This can cause some odd things to happen if your power supply is slow rising.
    You don't need to configure ADCON0 or VRCON unless you're using A/D & comparators.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    GregK's Avatar
    GregK Guest
    Default 12f683
    Hi Bruce,
    I tried your changes and it works like a charm!
    Now if I can get the rest of the program to work.
    Thanks for your help.
    Greg
  1. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 18:38
  2. 12F683 Programmer
    By Red_Stafford in forum Schematics
    Last Post: - 2nd October 2008, 22:44
  3. 12F683 HPWM Usage
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 03:16
  4. 16f677a to 12f683
    By ChrisHelvey in forum mel PIC BASIC Pro
    Last Post: - 25th July 2007, 07:16
  5. 12f683 comparator and pwm
    By Automan in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2007, 19:05
