Timing problem PIC18F2550
Results 1 to 6 of 6
    Mar 2011
    Default Re: Timing problem PIC18F2550
    Doesn't the meprogrammer have all the settings built into their little drop down menu? Therefore it should just be a matter of selecting the correct settings correct?
    Many come here thinking they can use the drop down and many end up learning how to set the configs the "right" way.
    This should help you get started on that path.
    Aug 2010
    Maryland, USA
    I must admit, programming for many years in ASM, I always set my configs through the MPLAB menu. Always worked great, and ALWAYS messed me up when I had to program more chips for the same job. Take the time to learn to set them in your program. You will hate it at first, but later you will be so happy when you don't have to remember how you set them for each application.
    -Bert
    Aug 2005
    Place
    DEFINE OSC 48
    at the beginning of your code and you should be sorted.
    Cheers
    Sean.
    http://www.cncdudez.co.uk
