Calculation error within a for next loop
Results 1 to 3 of 3
    Sep 2006
    Default Calculation error within a for next loop
    I have some weird going on. When the voltage_check value come to 220 the output shows 1% instead of the calculated 67%
    I have both voltage_check , voltage_percent as var word
    anybody knows why ? running on a 18F4550
    for i=215 to  230
    voltage_check =i
    		voltage_percent = (((voltage_check -179) * 1623 )    / 10 )
    lcdout $FE,1, "Output","  ", dec (voltage_percent / 100) ,".", dec2 (voltage_percent // 100 )
    lcdout $FE,$C0, "Ana4: ", dec voltage_check
    next i
    Bombay, India
    Default Re: Calculation error within a for next loop
    Typical problem of word size and technique.
    Take i = 220
    Now, plug into the formula
    220-179 = 41
    41 * 1623 = 66543
    which ends up in the variable as 66543-65535(0FFFFH) = 1008
    Now, you do the rest of the math and end up with the 1%
    You need to re-factor the way you calculate the problem.
    Sep 2006
    aaarg yep correct thank you
    K
