Hello,
I recently bought microcode studio and the PBP compiler. I am using the U2 programmer to perform ICSP on my 18F2550 PIC. I can program the chip no problem however the timing is no where near correct. For example I programed an LED to blink every seven seconds and it was blinking around every 5-6 secs. I think that i have the options wrong in the melabs programmer configuration window. As far as ocsillators go i am using a 20MHz crystal oscillator. I know the hardware setup is correct because i used the same hardware a couple of years ago when i was using this stuff in highschool (forgot most of it by now).
I was hoping someone could suggest the options i should use. I want to use the external 20MHz oscillator.
Eric
