Counting time via external pulses
Results 1 to 3 of 3
    Aug 2007
    Default Counting time via external pulses
    Hello!
    I've have one thing to do, but my experiance is low in this area.....this is the deal, I have two pulses comming from electronic that is allready excist, when pulse A is comming I should count in one direction, and when pulse B comming I should count opposite.
    This is the deal, say on input A when I got pulse, controller should count, so every 12 counte's is one secound, after secound it goes minutes, houres normal, in case signal comes to input it should come same, but only in opposite direction. Probably is simple thing to do, but I don't have clue where to start, specially this part when time is included.
    thanks.
    Default Re: Counting time via external pulses
    Pseudo code.
    IF PULSE THEN
    SEC = SEC + 1
    IF SEC = 60 THEN
    SEC = 0
    MIN = 1
    Aug 2007
    I did that, now my main problem is counting backwards......problem is if I count backward evrytime secounds passes 59 to 00 minute raises for 1, same happend if I go backward, but if should decrese
    this is my code:
    loop1:
    if porta.1=0 then
    counter=counter+1
    if counter == 12 then
    sekunda = sekunda +1
    counter = 0
    if sekunda == 60 then
    minuta = minuta +1
    sekunda = 0
    IF minuta == 60 then
    sat = sat +1
    minuta =0
    goto lcd
    if porta.0=0 then
    if counter == 0 then
    counter = 12
    if sekunda == 0 then
    sekunda = 60
    sekunda = sekunda -1
    counter=counter-1
    goto lcd
    goto loop1
    lcd:
    lcdout $fe,$c0,dec2 counter,"TCR:",DEC2 sat,":", dec2 minuta,":",dec2 sekunda
    while (porta.0=0 or porta.1=0)ause 10:wend
    goto loop1
