sinusoidal PWM
Results 1 to 40 of 84
Thread: sinusoidal PWM
    Feb 2011
    Default Re: sinusoidal PWM
    Something is not right. Are you compiling for the right chip, the PIC16F877? Because it does have those registers and bits. Are you using MPASM as your assembler, because the include file requires this. Can you send me your myprogram.lst file? That might tell me more....
    Yes i'm compiling for the PIC16F877 using MPSAM as my assembler
    Feb 2011
    I've converted the .lst file into pdf format so that i will be able to attach it,hope it will still serve the purpose.....
