sinusoidal PWM
Results 1 to 40 of 84
Thread: sinusoidal PWM
    Default Re: sinusoidal PWM
    What exactly do you mean with SPWM? What does the S mean?
    If you're generating the PWM signal with CCP-module you'll need 3 CCP-modules to generate three individual PWM signals. As have already been suggested ditch the '877 and take a look at the 18F2431/4431 which is designed for motor control providing deadtime control and dedicated hardware fault inputs to disable the PWM signals - and more.
    If you need to stick to a 16 series PIC then use the parametric search tool at Microchips website to look up a PIC with three CCP-modules, perhaps the 16F777.
    I just looked briefly at the app-note you reference and they seem to be using a low-pass filter to get a "true" sine-wave output, to do that they calculated/estimated that at least 10PWM cycles is needed to bring the output voltage to the desired value.
    How many "steps" do you want, per period? Let's say you have a lookup table of 32 'steps'. Ie it takes 32 "updates" to create one full cycle of the sinewave, so at 50Hz you need to change the PWM dutycycle 50*32=1600 times per second, which means that you'll get atleast three full PWM cycles for each "step" with a 5kHz PWM frequency, I think that'll work.
    Oct 2011
    Hi !
    SPWM stands for Sinusoidal Pulse With Modulation.These signals will be used to control Three phase inverter.
    thankx
    I'm afraid the letter sequence SPWM actually was derived by Darrel for his contribution of Software Pulse Width Modulation.
    EN82fn
    That's what I thought but figured it couldn't be since we're talking about CCP-modules etc. Doesn't matter, now I know what the OP means although I've never heard the term before.
    Apr 2007
    Pennsylvania, USA
    Perhaps this thread will be of use to you.
    http://www.picbasic.co.uk/forum/showthread.php?t=1846
    Shawn
    Oct 2011
    Hi
    I download the pic16f777 datasheet from microchip website I go through it I found it does not much differ from that of pic16f7877 so it easy for me to shift from the PIC16877 to 16F777 which has three ccp modules for SPWM generation.
    thanx
    Sorry for delay in reply, now I 'm in seventh semister exam of my BSc in electrical eng.
    Oct 2011
    hi to all
    I try to simulator my code on IMPLAB simulator but I have not yet sussceed til now so I decide to simulator with pic 16F877 which is found in ISIS but when it comes to real environment(actual implementation) I 'm going to use pic16f777 , which I 'm waiting for it to come.
    Then
    can any one help me !
    how to take my waveform from digital oscilloscope in ISIS cauz I want to uploaad in this forum ,I try to print but the file does not contain any waveform. I have some problem on my ouputs.
    thankx.
