POT with LDR
Results 1 to 4 of 4
Thread: POT with LDR
    stu746's Avatar
    stu746 Guest
    Default POT with LDR
    I am trying to use an ldr with the pot command, i tried connecting it in this order - pin-> ldr-> cap -> gnd
    and it seems to work, but not very well, if i cover the ldr i get a value of zero from POT, at normal room light i get about 150, if I cover it slightly the vlaue goes down, but if i shine a torch on it it goes down again to about 30!?
    I tried connecting the pin to the cap to gnd, and the pin to the ldr to +5v, but could not get it to work at all.
    I belive the second way to be the correct way to wire it? I have tried different values from 1 to 255 for pot with no effect.i just get a reading of 0 which will not change.
    Thanks for any help, Stu
    Cool
    Hi, Stu
    Everything in the manual ; 5k to 50k for LDR resistance ... no less, no more
    Have a look to RCTime ... wider possible range !!!
    stu746's Avatar
    stu746 Guest
    in the end i connected both the cap and ldr to gnd but still was not right, so used to following code and seems to work fine
    aa var word
    trisd.7=0
    high portd.7
    trisd.7=1
    loop6:
    aa=aa+1
    if aa=65000 then aa=aa-1
    if portd.7 = 1 then loop6
    serout portb.0,n2400,[#aa,13,10]
    there is probably a better way to do it, but this seems to work for me
    Feb 2004
    Germany
    Stu,
    as Alain already mentioned, it's all in the Manual.
    POT is a bit of a pain, does your PIC have a spare ADC?
    if yes, wire the LDR with an additional resistor as voltage divider and use ADCIN
    regards
    Ralph
  1. Using the Pot command.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 17th August 2009, 20:23
  2. POT command
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 4th December 2008, 22:33
  3. A/D, Pot, Input, A,B So lost now....
    By Helmutt in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 22:23
  4. Replies: 4
    Last Post: - 24th January 2007, 22:20
  5. pot controlled pwm -- help
    By docwisdom in forum mel PIC BASIC Pro
    Last Post: - 29th January 2006, 12:29
