Open source PBP bootloader
Results 1 to 40 of 41
    Default Re: Open source PBP bootloader
    Don't quote me on this just yet, but I think the 18's use a word for the data, so then it would make sense.
    Oops, just quoted you .....
    If that is true, then we should be good with the standard 32 bytes (if it is in bytes for 16F's) of data, then adding the 5 bytes for:
    DATA_BUFF   VAR BYTE[37]        ' Start of receive buffer SAME ADDRESS AS COMMAND
    COMMAND     VAR DATA_BUFF[0]    ' Data mapped in receive buffer SAME ADDRESS AS DATA_BYTE
    DATA_COUNT1 VAR DATA_BUFF[1]
    ADDRESS_L   VAR DATA_BUFF[2]
    ADDRESS_H   VAR DATA_BUFF[3]
    ADDRESS_U   VAR DATA_BUFF[4]
    PACKET_DATA VAR DATA_BUFF[5-36]    'THIS SHOULD BE AN ARRAY I THINK**************
    would be 37 bytes for 12F and 16F devices, leaving more room for variables in case we want more PBP bells and whistles later. Then for the 18F's, they all use the 128 words (maybe).
    Aug 2010
    Maryland, USA
    Newest update, includes Walter's last post regarding Array size. I have to stop here to think about what I am doing. I DON'T like the Read Program Memory at the end. I think it will work as is, but it really looks like ASM to me. I think I need to utilize the READCODE command, just not sure yet how to deal with the address and data. I assume maybe the address needs to be a word, comprised of EEADRH,EEADR. Then I guess the data is also a word. then I guess I just add 2 to the ARRAYPOINTER?
    IF anyone wants to chime in on this, now is a good time
    As a side note, IF anyone wants to help with this conversion, clearly I am working from the top down. If someone were to work from the bottom up, It would be easy for me to add it to what I have. Then when we meet in the middle, we will be done. No Biggie either way.
    ANY testers out there? Still looking for some. I will be able to test compile, but don't feel comfy trying to test the code as I have never used a bootloader so I won't know if problems are with my setup or the code.
    '        Software License Agreement
    ' The software supplied herewith by PBP forum members
    ' (the “Company”) for Microchip's PICmicro® Microcontroller's is
    ' intended and supplied to you, the Company’s customer, for use
    ' solely and exclusively on Microchip PICmicro Microcontroller
    ' products. The software is owned by the Company and/or its
    ' supplier, and is protected under applicable copyright laws. All
    ' rights are reserved. Any use in violation of the foregoing
    ' restrictions may subject the user to criminal sanctions under
    ' applicable laws, as well as to civil liability for the breach of
    ' the terms and conditions of this license.
    ' THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
    ' WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
    ' TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
    ' PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
    ' IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
    ' CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
    ' This software has been ported from Microchip's AN851 bootloader
    ' Changes have been made and will be made as the company sees fit.
    ' This version is for 16F's, there is another version for 18F's
    ' Memory Map
    '    |    0x0000    |    Reset vector
    '   |    0x0004    |    Interrupt vector
    '    |Boot Block |    (this program)
    '    |    0x0200    |    Re-mapped Reset Vector
    '    |    0x0204    |    Re-mapped High Priority Interrupt Vector
    '   |Code Space |    User program space
    '    |    0x3FFF |
    ' Incomming data format:
    '   {STX}{STX}{DATA}{CHKSUM}{ETX}
    '     ________/      \____________________________
    '    {COMMAND}{DLEN}{ADDRL}{ADDRH}{ADDRU}{DATA}...
    ' Definitions:
    '     STX      -    Start of packet indicator
    '    ETX     -    End of packet indicator
    '     LEN     -    Length of incomming packet
    '     DATA    -    General data up to 255 bytes
    '     CHKSUM     -     The 8-bit two's compliment sum of LEN & DATA
    '     COMMAND -     Base command
    '     DLEN    -    Length of data associated to the command
    '     ADDR    -    Address up to 24 bits
    '     DATA     -    Data (if any)
    ' Commands:
    '     RD_VER        00    Read Version Information
    '     RD_MEM        01    Read Program Memory
    '     WR_MEM        02    Write Program Memory
    '     ER_MEM        03    Erase Program Memory (NOT supported by PIC16)
    '     RD_EE        04    Read EEDATA Memory
    '     WR_EE        05    Write EEDATA Memory
    '     RD_CONFIG    06    Read Config Memory (NOT supported by PIC16)
    '     WT_CONFIG    07    Write Config Memory (NOT supported by PIC16)
    CHKSUM        VAR    BYTE        ' Checksum accumulator
    COUNTER        VAR    BYTE        ' General counter
    ABTIME        VAR    BYTE
    RXDATA        VAR    BYTE
    TXDATA        VAR    BYTE
    TEMP        VAR    BYTE
    ARRAYPOINTER VAR BYTE
    FAKEW        VAR BYTE
    TEMPFLAG    VAR BIT
    PCLATH_TEMP    VAR    BYTE        ' Interrupt context
    STATUS_TEMP    VAR    BYTE        ' save/restore registers
    W_TEMP        VAR    BYTE
    ' Frame Format
    '  {STX}{STX}[{COMMAND}{DATALEN}{ADDRL}{ADDRH}{ADDRU}{...DATA...}]{CHKSUM}{ETX}
    DATA_COUNT    VAR    DATA_BUFF[1]
    PACKET_DATA    VAR    DATA_BUFF[5]    'Is this Valid? It is now!
    '  This is the remapping section, note the interrupt also saves context
    @    ORG    0x0000            ' Re-map Reset vector **Not sure how to set the address to start at
    VReset:
        PCLATH = 0
        goto    Setup
    @    ORG    0x0004            'standard interrupt vector **again not sure of the PBP equal for ORG
    VInt:
        W_TEMP = W               'I am assuming this will be the "W" register
        STATUS_TEMP = STATUS   'We may have trouble here. ASM uses SWAP so as not to affect the status
        STATUS = 0
        PCLATH_TEMP = PCLATH
        PCLATH = 0
        goto    RVInt        ' Re-map Interrupt vector
    ' Setup the appropriate registers.
    Setup:
        clrwdt
        READ $ff,temp                 'get the value of last EEPROM location
        IF temp = $ff then goto SRX  'BL startup
        goto    RVReset                 ' If not 0xFF then normal reset
    SRX:
        RCSTA = %10000000        ' Setup rx and tx, CREN disabled
        TRISC.6 = 0             ' Setup tx pin
        TXSTA = %00100110
        STATUS.IRP = 1
    Autobaud:
    ' ___     __________            ________
    '    \__/           \__________/
    '       |-------- p ----------|
    '    p = The number of instructions between the first and last
    '           rising edge of the RS232 control sequence 0x0F. Other
    '        possible control sequences are 0x01, 0x03, 0x07, 0x1F,
    '         0x3F, 0x7F.
    '    SPBRG = (p / 32) - 1      BRGH = 1
        OPTION_REG = %00000011    'sets tmr0 to 1:16 prescale
        STATUS.RP0    = 0
        RCSTA.CREN = 0
        gosub    WaitForRise
        TMR0 = 0             ' Start counting
        gosub    WaitForRise
        ABTIME = TMR0         ' Read the timer
        TEMPFLAG = ABTIME.0
        ABTIME = ABTIME }}1
        IF !TEMPFLAG THEN ABTIME.0 = 0 'Rounding
        SPBRG = ABTIME
        RCSTA.CREN = 1         ' Enable receive
        TEMP = RCREG        ' To clear the Rx buffer
        TEMP = RCREG        ' Both of them
        OPTION_REG = %11111111 'Return Option Reg to reset state
    ' Read and parse the data.
    StartOfLine:
        GOSUB    RdRS232            ' Look for a start of line
        IF RXDATA != STX THEN Autobaud        '{STX}{STX}
        ARRAYPOINTER = 0        ' Point to the beginning of Array
        CHKSUM    = 0             ' Reset checksum
    GetNextDat:
        GOSUB    RdRS232            ' Get the data
        IF RXDATA = STX    THEN StartOfLine    ' Check for a STX
                                ' Yes, start over
    NoSTX:
        IF RXDATA = ETX THEN CheckSum    ' Check for a ETX
                                    ' Yes, examine checksum
    NoETX:
        IF RXDATA = DLE THEN GOSUB RdRS232 ' Check for a DLE
                                           ' Yes, Get the next byte
    NoDLE:
        DATA_BUFF[ARRAYPOINTER] = RXDATA   ' Store the data
        CHKSUM = CHKSUM + RXDATA           ' Get sum
        ARRAYPOINTER = ARRAYPOINTER + 1
        goto    GetNextDat
    CheckSum:
        IF CHKSUM = 0 THEN Autobaud  ' Checksum test
    ' Pre-setup, common to all commands.
        EEADR = ADDRESS_L        'Set all possible pointers
        EEADRH = ADDRESS_H
        ARRAYPOINTER = 5        'start of data in array
        COUNTER = DATA_COUNT     'Setup counter
        IF COUNTER = 0 THEN VReset    'Non valid count (Special Command)
    ' Test the command field and sub-command.
    CheckCommand
        IF COMMAND } 7 THEN Autobaud ' Test for a valid command
        SELECT CASE COMMAND          ' Perform calculated jump
            CASE 0
                goto    ReadVersion        ' 0
            CASE 1
                goto    ReadProgMem        ' 1
            CASE 2
                goto    WriteProgMem    ' 2
            CASE 3
                goto    StartOfLine        ' 3
            CASE 4
                goto    ReadEE            ' 4
            CASE 5
                goto    WriteEE            ' 5
            CASE 6
                goto    StartOfLine        ' 6
            CASE 7
                goto    StartOfLine        ' 7
        'maybe add jump to reset vector in this table
    ' Commands
    ' ************* Read Version
    ' In:    {STX}{STX}[{0x00}{0x02}]{0xFF}{ETX}
    ' OUT:    {STX}{STX}[{0x00}{VERL}{VERH}]{CHKSUM}{ETX}
    ReadVersion:
        DATA_BUFF[2] = MINOR_VERSION
        DATA_BUFF[3] = MAJOR_VERSION
        FAKEW = 4
        goto    WritePacket
    '*************Read Program Memory
    ' In:    {STX}{STX}[{0x01}{DLEN}{ADDRL}{ADDRH}{ADDRU}]{CHKSUM}{ETX}
    ' OUT:    {STX}{STX}[{0x01}{DLEN}{ADDRL}{ADDRH}{ADDRU}{DATA}...]{CHKSUM}{ETX}
    ReadProgMem:
    RPM1:
        EECON1.EEPGD = 1
        EECON1.RD = 1
        @nop                'not sure how to convert this to PBP
        @nop
        DATA_BUFF[ARRAYPOINTER] = EEDATA
        DATA_BUFF[ARRAYPOINTER] = EEDATH
        EEADR = EEADR + 1
        IF EEADR = 0 then
           EEADRH = EEADRH + 1
        COUNTER = COUNTER - 1
        IF COUNTER > 0 THEN RPM1            ' Not finished then repeat
        DATA_COUNT = (DATA_COUNT << 1) + 5    ' Setup packet length
        goto    WritePacket
    '************* Write Program Memory
    Last edited by ScaleRobotics; - 4th March 2011 at 18:21. Reason: declared PACKET_DATA to [5]
    -Bert
