Open source PBP bootloader
Results 1 to 40 of 41
    Aug 2010
    Maryland, USA
    Default Re: Open source PBP bootloader
    PJALM, That sounds pretty awesome, and aggressive!
    After doing some googling, There is at least 1 open source python interface out there to talk to AN851 BL. I like that approach, Python I mean, then we have multiplatform available.
    Ok, we have 2 responses so far. I have no idea how to tend to the logistics of this - meaning making it a group effort- or if we just contribuite code until we get something working. Baring any other suggestions, I will start to port AN851 to PBP.
    We will also need TESTERS!!!
    -Bert
    Aug 2010
    Maryland, USA
    This is where I am so far. I am sure there are some errors, but what are friends for?
    '        Software License Agreement
    ' The software supplied herewith by PBP forum members
    ' (the “Company”) for Microchip's PICmicro® Microcontroller's is
    ' intended and supplied to you, the Company’s customer, for use
    ' solely and exclusively on Microchip PICmicro Microcontroller
    ' products. The software is owned by the Company and/or its
    ' supplier, and is protected under applicable copyright laws. All
    ' rights are reserved. Any use in violation of the foregoing
    ' restrictions may subject the user to criminal sanctions under
    ' applicable laws, as well as to civil liability for the breach of
    ' the terms and conditions of this license.
    ' THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
    ' WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
    ' TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
    ' PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
    ' IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
    ' CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
    ' This software has been ported from Microchip's AN851 bootloader
    ' Changes have been made and will be made as the company sees fit.
    ' This version is for 16F's, there is another version for 18F's
    ' Memory Map
    '	|    0x0000	|	Reset vector
    '   |    0x0004	|	Interrupt vector
    '	|Boot Block |	(this program)
    '	|    0x0200	|	Re-mapped Reset Vector
    '	|    0x0204	|	Re-mapped High Priority Interrupt Vector
    '   |Code Space |	User program space
    '	|    0x3FFF |
    ' Incomming data format:
    '       <STX><STX><DATA><CHKSUM><ETX>
    '	 ________/      \____________________________
    '	<COMMAND><DLEN><ADDRL><ADDRH><ADDRU><DATA>...
    ' Definitions:
    ' 	STX  	-	Start of packet indicator
    '	ETX 	-	End of packet indicator
    ' 	LEN 	-	Length of incomming packet
    ' 	DATA	-	General data up to 255 bytes
    ' 	CHKSUM 	- 	The 8-bit two's compliment sum of LEN & DATA
    ' 	COMMAND - 	Base command
    ' 	DLEN	-	Length of data associated to the command
    ' 	ADDR	-	Address up to 24 bits
    ' 	DATA 	-	Data (if any)
    ' Commands:
    ' 	RD_VER		0x00	Read Version Information
    ' 	RD_MEM		0x01	Read Program Memory
    ' 	WR_MEM		0x02	Write Program Memory
    ' 	ER_MEM		0x03	Erase Program Memory (NOT supported by PIC16)
    ' 	RD_EE		0x04	Read EEDATA Memory
    ' 	WR_EE		0x05	Write EEDATA Memory
    ' 	RD_CONFIG	0x06	Read Config Memory (NOT supported by PIC16)
    ' 	WT_CONFIG	0x07	Write Config Memory (NOT supported by PIC16)
    CHKSUM		VAR	BYTE		' Checksum accumulator
    COUNTER		VAR	BYTE		' General counter
    ABTIME		VAR	BYTE
    RXDATA		VAR	BYTE
    TXDATA		VAR	BYTE
    TEMP		VAR	BYTE
    PCLATH_TEMP	VAR	BYTE		' Interrupt context
    STATUS_TEMP	VAR	BYTE		' save/restore registers
    W_TEMP		VAR	BYTE
    ' Frame Format
    '  <STX><STX>[<COMMAND><DATALEN><ADDRL><ADDRH><ADDRU><...DATA...>]<CHKSUM><ETX>
    DATA_BUFF	VAR	BYTE		' Start of receive buffer SAME ADDRESS AS COMMAND
    COMMAND		VAR	BYTE		' Data mapped in receive buffer SAME ADDRESS AS DATA_BYTE
    DATA_COUNT	VAR	BYTE
    ADDRESS_L	VAR	BYTE
    ADDRESS_H	VAR	BYTE
    ADDRESS_U	VAR	BYTE
    PACKET_DATA	VAR	BYTE	     'THIS SHOULD BE AN ARRAY I THINK**************
    '  This is the remapping section, note the interrupt also saves context
    @	ORG	0x0000			' Re-map Reset vector **Not sure how to set the address to start at
    VReset:
    	PCLATH = 0
    	goto	Setup
    @	ORG	0x0004			'standard interrupt vector **again not sure of the PBP equal for ORG
    VInt:
    	W_TEMP = W			   'I am assuming this will be the "W" register
    	STATUS_TEMP = STATUS   'We may have trouble here. ASM uses SWAP so as not to affect the status
    	STATUS = 0
    	PCLATH_TEMP = PCLATH
    	PCLATH = 0
    	goto	RVInt	    ' Re-map Interrupt vector
    ; Setup the appropriate registers.
    Setup:
    	clrwdt
    	READ $ff,temp		         'get the value of last EEPROM location
    	IF temp = $ff then goto SRX  'BL startup
    	goto	RVReset			     ' If not 0xFF then normal reset
    SRX:
    	RCSTA = b'10000000'		' Setup rx and tx, CREN disabled
    	TRISC.6 = 0 			' Setup tx pin
    	TXSTA = b'00100110'
    	STATUS.IRP = 1
    Well it formats much better in notepad++. well I tried to attach the code, but had some issues there. but for now, the code is as I wrote it, just the comments are messed up.
    -Bert
