Adcon register with P18F4550
Results 1 to 14 of 14
    Sep 2006
    Default Adcon register with P18F4550
    Hi ,
    I am trying to use A/D conversion, but my code compiles but does not even get to main loop when I add ADCON1 AND ADCON2 registers, these are valid registers in this pic, anybody knows why?
    ADCON0 = %11000001 ' AN0, Configure and turn on A/D Module
    'ADCON1 = %10001001 ' Analog input
    'ADCON2 = %10000001 ' Right justified results for 10 bits,Fosc/8
    K
    Default Re: Adcon register with P18F4550
    ADCON0 and ADCON1 bits 6 and 7 should both be 0.
    Are you using ADCIN or working the registers? Show your code.
    Sep 2006
    Ok Thanks , I wiil try it, but the datasheet sheet says: bit 7-6 Unimplemented: Read as ‘0’ .. shouldn't there be no difference as what is there?
    ok work now, but gives me an 8 bit result instead of 10 bit
    K
    Sep 2006
    I also have these defines in the prog:
    Define ADC_BITS 10 ' Set number of bits in result
    Define ADC_SAMPLEUS 50 ' Set sampling time in uSec
    K
    Adcon2.7=1
    Sep 2006
    ya thats what i had before I commented out. See I have 2.23v on pin ANA5 and it reading 93 on the LCD
    K
    Sep 2006
    I change a bit of the program , but i am still getting 8 bit results ( max 255)
    ADCON0 = %00000001 ' AN0, Configure and turn on A/D Module
    ADCON1 = %00001001 ' Analog input
    ADCON2.7 =1 	   ' Right justified results for 10 bits,Fosc/8
    Check_voltage_Low:
    ADCON0 = 00010001 'Start Conversion
    ADCON2.7 =1
    ADCIN 4, voltage_check 'analog pin 4 get the 10 bit result  Check the battery voltage on pin PORTA.5
    lcdout $FE,1, "Battery voltage"
    lcdout $FE,$C0, "TempC: ",  dec voltage_check
    pause 1500
    I never did like ADCIN. Take a look at this thread. It may help.
    http://www.picbasic.co.uk/forum/show...9694#post79694
    Sep 2006
    Thanks Dave, its working now with your method.
    still wandering why the button command do not work.
    Sep 2006
    I added a 1uF capacitor to the analog pin, hoping it would stabilize the voltage. I am measuring a 12v battery, using a 80Mohm and a 16Mohm divider. I am reading about 2.2v on the pin, but the output oscillates between 425, 429, 433. which seems to be a lot. any other things I can do to stabilize the output ? (hardware) I am also thinking of taking an average of the last three inputs..
    K
    Sep 2006
    Hi , I added these lines: but it still fluctuates a lot:
    then I output the ChAN_AVG
        GOSUB   READ_AD
    	CHAN4_2 = CHAN4_1
    	CHAN4_1 = CHAN4
        CHAN4.HighByte = ADRESH  'PLACES THE HIGH AND LOW BYTE
        CHAN4.LowByte  = ADRESL   'INTO VAR CHAN0
    	CHAN_AVG = (CHAN4_2 + CHAN4_1 + CHAN4 ) /3
    On similar apps I use a 22uF cap from the ADC pin to VSS.
    How stable is VDD?
    Sep 2006
    I use a 7805 with a 1uF cap and a 47uF cap on the adc pin
    K
    Feb 2011
    Michigan, USA
    I believe your problem is this "80Mohm and a 16Mohm divider".
    See section 21.1 in 18F4550 spec sheet.
    It says the maximum recommended impedance for analog
    sources is 2.5 kΩ.
