Charles,
Were you testing this by boot-loading with the internal osc and a serial loader, or just testing to see if the PIC failed at these temps?We have chamber-tested random units at -40C and 100C, about 30 units total.
If so - which PIC were you using? I've had problems in Colorado when the temperature fell below freezing with serial loaders using the internal osc. And more when the board was in an enclosure exposed to direct sun.
Just curious. That's pretty good if you were boot-loading with a serial loader using the internal osc at these temperatures.
