Mecanique's internal bootloader OSC
Results 1 to 37 of 37
    Default Re: Mecanique's internal bootloader OSC
    Quote Originally Posted by SUNFLOWER View Post
    MicroChip Bootloader P1618QP.EXE and Tiny_Loader both have the same conflict with internal oscillators and bootloaders.
    Yes they do. But with Tiny Bootloader, they give you the source code, so you can change anything you want. Although, Charles has me interested about disassembling the MCLoader files! Thanks Charles, I will try that!
    Here is a modified Tiny Bootloader. Untested, but here are the changes I made.
        radix DEC
        LIST      P=18F4620    ; change also: Configure->SelectDevice from Mplab
    xtal EQU 4000000        ; set for 4 mhz you may want to change: _XT_OSC_1H  _HS_OSC_1H  _HSPLL_OSC_1H
    baud EQU 9600            ; the desired baud rate
        ; The above 3 lines can be changed and buid a bootloader for the desired frequency (and PIC type)
        ;    Tiny Bootloader        18F series        Size=100words
        ;    [email protected]
        ;    http://www.etc.ugal.ro/cchiculita/software/picbootloader.htm
        #include "icdpictypes.inc"    ;takes care of: #include "p18fxxx.inc",  max_flash, IdTypePIC
        #include "spbrgselect.inc"    ; RoundResult and baud_rate
            #define first_address max_flash-200        ;100 words
        __CONFIG _CONFIG1H, _OSC_INTIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOREN_OFF_2L
        __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_1_2H
        __CONFIG _CONFIG3H, _MCLRE_ON_3H & _PBADEN_OFF_3H & _CCP2MX_PORTBE_3H
        __CONFIG _CONFIG4L, _DEBUG_OFF_4L & _LVP_OFF_4L & _STVREN_OFF_4L & _XINST_OFF_4L
        __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L
        __CONFIG _CONFIG5H, _CPB_OFF_5H
        __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L
        __CONFIG _CONFIG6H, _WRTB_OFF_6H & _WRTC_OFF_6H
        __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L
        __CONFIG _CONFIG7H, _EBTRB_OFF_7H & _DEVID1 & _IDLOC0
    ;----------------------------- PROGRAM ---------------------------------
        cblock 0
        crc
        i
        cnt1
        cnt2
        cnt3
        counter_hi
        counter_lo
        flag
        endc
        cblock 10
        buffer:64
        endc
    SendL macro car
        movlw car
        movwf TXREG
    ;0000000000000000000000000 RESET 00000000000000000000000000
            ORG     0x0000
            GOTO    IntrareBootloader
    ;view with TabSize=4
    ;&&&&&&&&&&&&&&&&&&&&&&&   START     &&&&&&&&&&&&&&&&&&&&&&
    ;----------------------  Bootloader  ----------------------
    ;PC_flash:        C1h                U        H        L        x  ...  <64 bytes>   ...  crc
    ;PC_eeprom:        C1h                   40h   EEADR   EEDATA    0        crc
    ;PC_cfg            C1h            U OR 80h    H        L        1        byte    crc
    ;PIC_response:       type `K`
        ORG first_address        ;space to deposit first 4 instr. of user prog.
        nop
        nop
        nop
        nop
        org first_address+8
    IntrareBootloader
                                ;init serial port
        movlw b'00100100'
        movwf TXSTA
        movlw spbrg_value
        movwf SPBRG
        movlw b'10010000'
        movwf RCSTA
        movlw b'01100000'        ;ADDED to set osccon to 4mhz internal
        movwf OSCCON
                                ;wait for computer
        rcall Receive
        sublw 0xC1                ;Expect C1h
        bnz way_to_exit
        SendL IdTypePIC            ;send PIC type
    MainLoop
        SendL 'K'                ; "-Everything OK, ready and waiting."
    mainl
        clrf crc
        rcall Receive            ;Upper
        movwf TBLPTRU
            movwf flag            ;(for EEPROM and CFG cases)
        rcall Receive            ;Hi
        movwf TBLPTRH
            movwf EEADR            ;(for EEPROM case)
        rcall Receive            ;Lo
        movwf TBLPTRL
            movwf EEDATA        ;(for EEPROM case)
        rcall Receive            ;count
        movwf i
        incf i
        lfsr FSR0, (buffer-1)
    rcvoct                        ;read 64+1 bytes
            movwf TABLAT        ;prepare for cfg; => store byte before crc
        rcall Receive
        movwf PREINC0
        decfsz i
        bra rcvoct
        tstfsz crc                ;check crc
        bra ziieroare
            btfss flag,6        ;is EEPROM data?
            bra noeeprom
            movlw b'00000100'    ;Setup eeprom
            rcall Write
            bra waitwre
    noeeprom
            btfss flag,7        ;is CFG data?
            bra noconfig
            tblwt*                ;write TABLAT(byte before crc) to TBLPTR***
            movlw b'11000100'    ;Setup cfg
            rcall Write
            bra waitwre
    noconfig
                                ;write
    eraseloop
        movlw    b'10010100'        ; Setup erase
        rcall Write
        TBLRD*-                    ; point to adr-1
    writebigloop
        movlw 8                    ; 8groups
        movwf counter_hi
        lfsr FSR0,buffer
    writesloop
        movlw 8                    ; 8bytes = 4instr
        movwf counter_lo
    writebyte
        movf POSTINC0,w            ; put 1 byte
        movwf TABLAT
        tblwt+*
        decfsz counter_lo
        bra writebyte
        movlw    b'10000100'        ; Setup writes
        rcall Write
        decfsz counter_hi
        bra writesloop
    waitwre
        ;btfsc EECON1,WR        ;for eeprom writes (wait to finish write)
        ;bra waitwre            ;no need: round trip time with PC bigger than 4ms
        bcf EECON1,WREN            ;disable writes
        bra MainLoop
    ziieroare                    ;CRC failed
        SendL 'N'
        bra mainl
    ;******** procedures ******************
    Write
        movwf EECON1
        movlw 0x55
        movwf EECON2
        movlw 0xAA
        movwf EECON2
        bsf EECON1,WR            ;WRITE
        nop
        ;nop
    Receive
        movlw xtal/2000000+1    ; for 20MHz => 11 => 1second delay
        movwf cnt1
    rpt2
        clrf cnt2
    rpt3
        clrf cnt3
    rptc
            btfss PIR1,RCIF            ;test RX
            bra notrcv
            movf RCREG,w            ;return read data in W
            addwf crc,f                ;compute crc
    notrcv
        decfsz cnt3
        bra rptc
        decfsz cnt2
        bra rpt3
        decfsz cnt1
        bra rpt2
        ;timeout:
    way_to_exit
        bcf    RCSTA,    SPEN            ; deactivate UART
        bra first_address
    ; After reset
    ; Do not expect the memory to be zero,
    ; Do not expect registers to be initialised like in catalog.
    Feb 2011
    Thanks scalerobotics. It worked crystal clear... only once. After that Tiny_bootloader could not find PIC unless it was totally erased, Tiny bootloader reloaded, then Tiny found PIC and Tiny programmed PIC, only once, then round we go again. So there is a conflict somewhere in the fog...
    Best,
    Doug
    It must be dirt cheap
    If you're not using a crystal just to keep costs down, why not get rid of the MAX IC, DB-9 connector, supporting caps, and just design-in a 5-pin header for in-circuit programming?
    The PGD and PGC pins could be used for serial communications if you need to monitor what's happening on the board.
    If this board will be installed outdoors, you're most likely going to have issues when attempting to boot-load new firmware anyhow due to changes in temperature. The internal osc is fine when indoors, but when exposed to extreme temp changes it will drift considerably, and you will have major problems just trying to load new firmware.
    You won't have that problem with in-circuit programming. A Pickit2 could be used for firmware updates & as the serial monitor if needed, and a Pickit2 costs even less than MCS+.
    Your board is a lot less expensive, and your programming tool is less expensive + more reliable, and you can use any internal osc speed you prefer.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
