Interrupt status?
Results 1 to 12 of 12
    Default Re: Interrupt status?
    Quote Originally Posted by circuitpro View Post
    Have I overlooked something about the INT_INT constants? Where to find out more on this?
    No, you haven't missed anything.
    I was just thinking about how I could make the interrupt bits available using the INT_INT constants. They've never been needed so far since the person writing the program is turning them on and off to begin with.
    What I came up with is pretty ugly and confusing, so probably won't help.
    But if you only have 4 interrupt sources, and they are interferring with each other ...
    You are probably trying to do too much in the handler.
    Interrupt rule number one.
    Get into the handler, do only what is necessary to service the interrupt and get out as fast as possible. No pauses, no serial input or output, no waiting for something else to happen.
    Anything that takes time should be done in the main loop.
    Default uart and interrupts
    Hey Darrel, I have a question about the rules. Would it break the rules if inside the interrupt handler you sent one or two bytes out at a time using the uart, as it would fit in the buffer?
    Default Re: uart and interrupts
    Sure, interfacing with the hardware is fine, then the hardware goes off and does the time consumming tasks.
    USART, MSSP, Timers, CCP modules, A/D converter etc. ... YES.
    SERIN/OUT(2), DEBUGIN/OUT, PULSIN/OUT, RCTIME, PAUSE, FREQOUT etc ... NO
    Dec 2008
    Los Angeles, CA
    Very good reminder in #7.
    I think I'll just need to go through the (INT0) handler and just pare the heck out of it.
    Dec 2008
    Los Angeles, CA
    I know about not using serial port/s during an interrupt, but how time consuming is something like this?
    ARRAYWRITE TEMP,[DEC2 HOST,".",DEC2 ADDRESS,".","125",".",DEC2 V,".","*",13,10]
    (I guess this would be considered 'hardware' and therefore probably permissible, right?)
