Adcon register with P18F4550
Results 1 to 14 of 14
    Sep 2006
    Default Re: Adcon register with P18F4550
    I added a 1uF capacitor to the analog pin, hoping it would stabilize the voltage. I am measuring a 12v battery, using a 80Mohm and a 16Mohm divider. I am reading about 2.2v on the pin, but the output oscillates between 425, 429, 433. which seems to be a lot. any other things I can do to stabilize the output ? (hardware) I am also thinking of taking an average of the last three inputs..
    K
    Sep 2006
    Hi , I added these lines: but it still fluctuates a lot:
    then I output the ChAN_AVG
        GOSUB   READ_AD
    	CHAN4_2 = CHAN4_1
    	CHAN4_1 = CHAN4
        CHAN4.HighByte = ADRESH  'PLACES THE HIGH AND LOW BYTE
        CHAN4.LowByte  = ADRESL   'INTO VAR CHAN0
    	CHAN_AVG = (CHAN4_2 + CHAN4_1 + CHAN4 ) /3
    On similar apps I use a 22uF cap from the ADC pin to VSS.
    How stable is VDD?
    Sep 2006
    I use a 7805 with a 1uF cap and a 47uF cap on the adc pin
    K
    Feb 2011
    Michigan, USA
    I believe your problem is this "80Mohm and a 16Mohm divider".
    See section 21.1 in 18F4550 spec sheet.
    It says the maximum recommended impedance for analog
    sources is 2.5 kΩ.
