I change a bit of the program , but i am still getting 8 bit results ( max 255)
Code:Define ADC_BITS 10 ' Set number of bits in result Define ADC_CLOCK 3 ' Set clock source (3=rc) Define ADC_SAMPLEUS 50 ' Set sampling time in uSec ADCON0 = %00000001 ' AN0, Configure and turn on A/D Module ADCON1 = %00001001 ' Analog input ADCON2.7 =1 ' Right justified results for 10 bits,Fosc/8 Check_voltage_Low: ADCON0 = 00010001 'Start Conversion ADCON2.7 =1 ADCIN 4, voltage_check 'analog pin 4 get the 10 bit result Check the battery voltage on pin PORTA.5 lcdout $FE,1, "Battery voltage" lcdout $FE,$C0, "TempC: ", dec voltage_check pause 1500 Return
