Problem with DATA in PBP
Results 1 to 12 of 12
    Feb 2004
    Germany
    Arch,
    DATA can handle strings, and kacho's code example is ok.
    The problem must be with his loader.
    I don't know this loader, so I cant tell wether or not there are options like
    - write code only
    - write data only
    - write code and data
    so far it looks like there has just no data been written.
    Let's wait for kacho to get back with his results from the test I have suggested.
    regards
    Ralph
    New England
    Hi Ralph,
    Yup - noticed that once I took a peek at the PBP manual (that's why I added the < EDIT > line to my original post).
    Now only if we could assign strings to arrays :-)
    Arch
    Feb 2004
    Germany
    This
    is a workaround to assign (static) strings to arrays
    regards
    Ralph
    Jun 2005
    Wisconsin
    The bootloader doesn't seem to program the onboard EEProm. I'm not entirely sure that it is supposed to.
    Post to the forum on the sparkfun site...sparky is pretty good about responding to posts.
    dynamoben, I have used strings with data statements before w/16f88 processors without any problems. Here ia a line of code I have used with a current project: INTRO DATA @0,10,13,"WHITBOX3.BAS (05/19/2005)",10,13,0
    The word "intro" is the data location pointer for the program. I quess I'm only saying that the statement you had used is good.....
    Jun 2005
    Wisconsin
    I'm not suggesting that the DATA statement won't work for that chip. I know DATA will work. However Screamer will not program the onboard eeprom (in my expirence). I'm currently working on a project with screamer and a 16F876A. When I program via the loader is doesn't reprogram my onboard EEProm values, I end up having to use a conventional programming method.
    DynamoBen, I also have an set of Screamer radios that I've had for about 2 years and a while back saw some email somewhere about using it to bootload pic processors. I haven't used them for that purpose as of yet but I'm interested in what you find out as for using them to bootload code over the air to a pic controlled device. I have used them in the past for remote control of an lawnmower that I built. Please keep me informed....
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  3. 16-bit SPI problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 16:42
  4. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  5. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
