Problem with DATA in PBP
Results 1 to 12 of 12
    kacho's Avatar
    kacho Guest
    Default Problem with DATA in PBP
    Hi ,
    I`m using PBP ,16F88 and Screamer bootloader.
    I try to store messages in the Eeprom but the sentence DATA @100, " HOLA GENTE " is ignored in the program
    I try to read the PIC con IC prog,and the eeprom don`t store the message ?.
    The rest of the program work perfect.WRITE and READ commands working OK,but DATA don`t work ??
    Here is an extract..
    FLAGS=0
    include "88.inc"
    define inthand myint
    Any help? ,thanks !!
    Feb 2004
    Germany
    kacho,
    the DATA statement in PBP works fine with the F88.
    have you viewed the HEX-file generated by PBP in MPLAB (or ICprog)?
    is there any EEPROM Data?
    case yes:
    Try to program the chip using ICprog, read it back and let us know the result.
    regards
    Ralph
    New England
    Hi kacho,
    I don't know if "DATA" can be used to write a string like that.
    Maybe try:
    DATA @100,72,79,76,65,32,71,69,78,84,69 ;ASCII values for " HOLA GENTE "
    (hope I got the ASCII codes right).
    Arch
    < EDIT >
    Hmmm... the manual says "DATA" can handle strings - strange.
    < EndEDIT >
    Feb 2004
    Germany
    Arch,
    DATA can handle strings, and kacho's code example is ok.
    The problem must be with his loader.
    I don't know this loader, so I cant tell wether or not there are options like
    - write code only
    - write data only
    - write code and data
    so far it looks like there has just no data been written.
    Let's wait for kacho to get back with his results from the test I have suggested.
    regards
    Ralph
    New England
    Hi Ralph,
    Yup - noticed that once I took a peek at the PBP manual (that's why I added the < EDIT > line to my original post).
    Now only if we could assign strings to arrays :-)
    Arch
    Feb 2004
    Germany
    This
    is a workaround to assign (static) strings to arrays
    regards
    Ralph
    Jun 2005
    Wisconsin
    The bootloader doesn't seem to program the onboard EEProm. I'm not entirely sure that it is supposed to.
    Post to the forum on the sparkfun site...sparky is pretty good about responding to posts.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  3. 16-bit SPI problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 16:42
  4. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  5. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
