Making a menu selection
Results 1 to 4 of 4
    Sep 2006
    Default Making a menu selection
    I am trying to make a menu selection SUB that will not exit until select button is pressed. I am using the PIC18F4550
    Selection var PortC.6
    Next1 var PortC.7
    '///////  GetModeOfOperation  ////////
    GetModeOfOperation:
    	Lookup Op_Mode, [55,65],Operation_Mode
    	Select Case Operation_Mode
    	Case 55
    		lcdout $FE,1,  " Charger Mode "
    	Case 65
    		lcdout $FE,1,  " Recycle Mode"
    	End Select
    		lcdout $FE,$C0, "Next or Select"
    		pause 200
    		if Selection=1 then return
    		if Next1=1 then Op_Mode = Op_Mode + 1
    		if Op_Mode > 1 then Op_Mode = 0
    		Gosub GetModeOfOperation
    The problem, is that my sub routine exits (return) after 4 seconds while nothing has been pressed.
    Aug 2010
    Maryland, USA
    Default Re: Making a menu selection
    Quote Originally Posted by lerameur View Post
    Next1 var PortC.7
    GetModeOfOperation:
    	Case 55
    	Case 65
    	End Select
    		pause 200
    I just learned today that in th 18's you can overflow the stack. I don't really know the what happens when you do, but I suspect a "reset" maybe. Anyhow, I think the gosub needs to be a goto. otherwise you just keep calling itself without a return. everytime it saves PC to the stack, but never reads it back.
    -Bert
    Sep 2006
    ok wow work great now, thank you
    K
    Bombay, India
    This should help you.
    Next1 var PortC.7
    GetModeOfOperation:
         while Selection = 0           ' exit when selection becomes 1
    	Case 55
    	Case 65
    	End Select
    		pause 200
         wend
