disabling the master clear bit MCLR OR MCLRE or using gpio.3 or pin4 or RA3
Results 1 to 3 of 3
    Feb 2011
    Default disabling the master clear bit MCLR OR MCLRE or using gpio.3 or pin4 or RA3
    see:
    http://www.picbasic.co.uk/forum/cont...o-your-Program
    see below the ?? for how I did this.
    Is there a better way to do this than changing the .INC file for each chip??
    Perspiring minds want to know
    doing this:
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    gets this error
    [error 118] ... overwriting previous address 2007h
    Want to use pin4?
    It will only be an INPUT.
    ' WHEN PROGRAMMING PROGRAM $2007.5 TO LOW THIS WILL ENABLE GPIO.3 / RA3 AS AN INPUT
    ' Set the 2007 Register BIT FIVE [5] to ZERO [0] *****************
    ----> I currently do this just before programming in the programmer configuration menu.
    'OR
    ' change the config file
    ' OR IN THE C:\PBP\chip.INC
    ' i.e. C:\PBP\12F683.INC
    change this line to:
    device pic12F683, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
    and this line to:
    ;*  12F683.INC                                                  *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2005 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 08/31/05                                        *
    ;*  Version   : 2.46a                                           *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            include 'M12F683.INC'	; PM header
    ;        device  pic12F683, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 12F683, r = dec, w = -302
            INCLUDE "P12F683.INC"	; MPASM  Header
    ;        __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
            NOLIST
            LIST
    Default Re: disabling the master clear bit MCLR OR MCLRE or using gpio.3 or pin4 or RA3
    Feb 2011
    Thumbs up Re: disabling the master clear bit MCLR OR MCLRE or using gpio.3 or pin4 or RA3
    Thanks Mackrackit -- that was the thread I pointed to at the top.
    After reading the thread yet again, : ) At a more reasonable time of day.
    Specifically folks want to see post#15.
    -- It says to just remove all of the config [ $2007] define code. SO the compiler won't be confused.
    -- And put the config info in your program, Just DON'T FORGET TO DO IT FOR EVERY PROGRAM.
    Or you can change it to what you normally want and be done with it like I suggested.
    Newbie error # 1,289 [Me, me, me]
    Of course this thread should also be called 'it won't run and I don't have a clue why'
    -- Pin4 is the master clear and is active low, so pull it high and your uC will start to work. Maybe, like hopefully
    Pull high means use a resistor 1k-470k.
