yeah im using a 4mhz xtal as theyre what I had handy at the time lol.
Im using your USB ints for controlling the USB and its set to 10ms interval on both the USB_POLLIN and USB_POLLOUT
Edit: USB interupts are running on TMR1
I don't know if this helps but I have had similar problems in the past and simply putting a capacitor from the USB V+ to GND worked every time. I always use a 0.1uF but it probably doesn't really matter what value.
Sorry Darrel, my mistake, the USB is running under the USB_HANDLER interupt, its my sub routine thats using TMR1 (late at night I posted that lol)
Will try the cap across the pins and see if that remedies the problem as it is a bit of a headache having to remove the LED light unit from where it is to access the pic so I can edit the settings etc.
Edit: just realised, do you mean the 5V to GND of the USB? as on my pcb (and breadboard) I never wired up the 5V as I dont need to use the 5v from the USB so thought better to be safe and not connect it anywhere on the PCB just in case the 2 different 5v sources made things go pop etc! Only pins wired on the PCB side for the usb port are the D+/D- and GND.
Yes for some reason I have the same problem happen. Putting a cap across the USB V+ and GND seemd to fix it for me, I thought maybe it just needed some sort of load to make it work.
I don't seem to need it on breadboards either, very wierd.
Will have to try that but agree that it is very weird!! Will let you know if it does it for me too.
Amazing!! rebuilt the USB breakout board and put a cap across the 5v and GND and blow me it works! weird! but MANY MANY thanks for the info!!!
One (Almost) happy chappy![]()
