disabling the master clear bit MCLR OR MCLRE or using gpio.3 or pin4 or RA3
Results 1 to 3 of 3
Threaded View
  1. #3
    Feb 2011
    Thumbs up Re: disabling the master clear bit MCLR OR MCLRE or using gpio.3 or pin4 or RA3
    Thanks Mackrackit -- that was the thread I pointed to at the top.
    After reading the thread yet again, : ) At a more reasonable time of day.
    Specifically folks want to see post#15.
    -- It says to just remove all of the config [ $2007] define code. SO the compiler won't be confused.
    -- And put the config info in your program, Just DON'T FORGET TO DO IT FOR EVERY PROGRAM.
    Or you can change it to what you normally want and be done with it like I suggested.
    Newbie error # 1,289 [Me, me, me]
    Of course this thread should also be called 'it won't run and I don't have a clue why'
    -- Pin4 is the master clear and is active low, so pull it high and your uC will start to work. Maybe, like hopefully
    Pull high means use a resistor 1k-470k.
