IF ....THEN.... problems
Results 1 to 17 of 17
    Feb 2011
    Unhappy Re: IF ....THEN.... problems
    yes relay will be =1 . I will explain. The timer is hardware piece with ne 555 and it has a relay on board. The portb.0 turning on timer(with transistor), and timer relay is on(relay = 0) for some time depending of potentiometer position. After timer turn off(ne555 ), the portb.0 is still on, but timer is not on becouse ne555 turn it off.The relay is off but it is connected to a porta.1 like button. So if relay is off, the pin porta.1 is on high (1) (pull up resistor). That is why the relay = 1 (it should be off and portb.0 is on, but timer is off).
    I hope you have understand me .
    All I need is to do this, example:
    begin:
    IF step1 AND step2 THEN
    step3
    step4
    step5
    goto begin
    with this order.
    Aug 2010
    Maryland, USA
    Default Re: IF ....THEN.... problems
    so can you do this:
    IF (step 1) and (step 2) then : ' notice the : it lets you have multiple steps
     step 3
     step 4
     step 5
    did you try it with () around the conditions?
    -Bert
    Feb 2011
    Smile Re: IF ....THEN.... problems
    I am using 16F84, all porta have been declarated as inputs( it is like pushbuttons) It works on the begining.. Yes I`ve tried this with ( ) and there is no difference still not working as I want. Maybe this can be done with while....wend or for.... cycle....just don`t know how.
    May 2010
    Chile
    In 16F84 MCLR pin can't be disabled, so 4k7 resistor pullup to +5V or its never going to work
    Also for the used inputs use 10K pullups and instead of using the button command, try something a lot simpler:
    b0 = 0 'reset flag
    if ti = 0 then 'if pullup pin is in ground
        b0 = 1 'activate button press flag
        pause 250 'debounce
    Try explaining a little better your circuit so i can help you with your code (maybe an schematic or diagram?)
    Also remeber that a 16F84 its not the same as a 16F84A for the compiler, check for that.
    "If at first doesn't work, kicking it wont help either"
    Feb 2011
    Thanks for your quick response. I wroted a scheme, but it is hand drawing for now, I hope it will be ok.
    In the mean time, I found a way to get this work, but there is another problem again.
    This is code:
    TRISA = $FF 'Postavi sve pinove porta A kao ulazne
    TRISB = $00 'Postavi sve pinove porta B kao izlazne
    B0 var byte
    i var byte
    symbol t1 = porta.1
    symbol tajmer = portb.0
    symbol rele = porta.0
    begin:
    pause 100 'vrlo bitna pauza'
    while tajmer = 1 and rele = 1
    goto petlja
    petlja:
    i = 0
    for i = 1 to 2
    If i = 1 then
    pause 300
    goto petlja1
    if i = 2 then
    pause 300
    goto petlja2
    next i
    petlja1:
    PAUSE 500
    tajmer = 0 'iskljuci tajmer'
    portb.1 = 0 'ukljuci crvenu diodu veliku'
    pause 3000 'pauza 3 sekunde'
    petlja2:
    tajmer = 1
    portb.2 = 0 'ukljuci diodu zelenu'
    portb.1 = 1 'iskljuci crvenu diodu'
    pause 200
    wend 'vrlo bitna pauza'
    IF tajmer = 1 AND rele = 1
    portb.3 = 0
    portb.1 = 1
    portb.2 = 1
    B0 = 0
    button t1,0,255,0,B0,1,ukljucenje 'ako je taster pritisnut idi na ukljucenje'
    goto begin
    ukljucenje:
    tajmer = 1
    goto begin
    The commented is in Serbian so don`t look at it .
    The code do following: after press a pushbutton t1, tajmer is on and it works until it turn off, but only a timer. Its transistor is still on and have to be off and again on to reset. Now transistor for timer is off, some leds are on, pause 3 seconds, then on again transistor and timer, after a while timer goes off, and continuo for the begining again.
    The problem now is how to continue to cycle after wend and not to go from begin what this program do ? Becouse program after wend go from the begining again, not considering this IF...AND....Then after wend. I need this, and maybe more examining loops before going to begin again. Maybe this FOR cycle is not good?
    Kind regards.
    Aug 2010
    Maryland, USA
    Your IF..Then's are causing you to jump out of the for...next. If you change the GOTO to GOSUB, then add a RETURN after the blocks of code you are jumping to, maybe this will fix the problem.
    I must admit I don't really get the goal of your program, but I think you don't intend to jump out maybe?
    -Bert
    Feb 2011
    This with gosub works to, but the exactly same thing happens. I tried to put IF ...then condition in body of gosub to examin again but program just not "see" that and go again from the begin.
    Here is a new code:
    begin:
    goto petlja
    petlja:
    PAUSE 500
    pause 3000
    gosub petlja1 'iskljuci crvenu diodu
    petlja1:
    tajmer = 1 'ukljuci tajmer'
    portb.1 = 1 'iskljuci crvenu led'
    portb.2 = 0 'ukljuci zelenu led'
    B0 = 0
    goto begin
    ukljucenje:
    tajmer = 1
    goto begin
    The reason for using hardware timer is becouse I don`t know how to make it with microcontroller and potentiometer, maybe that will makes this code easier. In all this code very important information is when timer stops counting(countdown) which is enabled by relay which is similiar to pushbutton on porta.0.
