OK, Maybe I see the problem. AND MAYBE I can explain it. Here goes. This is your program from a few posts back with some added comments:
If you change the RED goto to gosub,add the returns, and move the petlja1 and petlja2 routines to the end of the program. It may act as you expect.Code:TRISA = $FF 'Postavi sve pinove porta A kao ulazne TRISB = $00 'Postavi sve pinove porta B kao izlazne B0 var byte i var byte symbol t1 = porta.1 symbol tajmer = portb.0 symbol rele = porta.0 begin: pause 100 'vrlo bitna pauza' while tajmer = 1 and rele = 1 ' when both are 1, we do this while loop goto petlja petlja: i = 0 for i = 1 to 2 If i = 1 then pause 300 goto petlja1' EVERY time timer and relay are 1, we go to petlja1 endif if i = 2 then pause 300 goto petlja2 endif next i petlja1: ' We are here because timer and relay are = 1 PAUSE 500 tajmer = 0 'iskljuci tajmer' ' now timer = 0? portRETb.1 = 0 'ukljuci crvenu diodu veliku' pause 3000 'pauza 3 sekunde' RETURN ' I think you need to add this here petlja2: ' We are here because we fall in here from petlja1 tajmer = 1 ' now timer = 1 again portb.2 = 0 'ukljuci diodu zelenu' portb.1 = 1 'iskljuci crvenu diodu' pause 200 RETURN' and here wend 'vrlo bitna pauza' ' go back and check while again. right now timer = 1, relay = ?? ' If relay also = 1, you will never get out of the loop. IF tajmer = 1 AND rele = 1 ' I think you will never get to this check, stuck in the while loop. portb.3 = 0 portb.1 = 1 portb.2 = 1 ENDIF B0 = 0 button t1,0,255,0,B0,1,ukljucenje 'ako je taster pritisnut idi na ukljucenje' goto begin ukljucenje: tajmer = 1 goto begin End
