For more versatility, you might consider this ...
The EXT (external) modifier.
Typcasting Variables inside of Arrays
http://www.picbasic.co.uk/forum/show...php?t=3891#TYP
Darrel, EXT can't be that versatile. I'm using the EXT modifier, its your code example I'm using.
Serout2 TX_USB, 84,[" DSvolts is ",bin DSvolts.highbyte,bin DSvolts.lowbyte,13,10]
this won't compile. Should it? Or could I have a Bank problem?
Code:DSbuffer VAR BYTE[9] BANK0 ASM ;Typcasting Variables inside of Arrays DSstat = _DSbuffer ; byte DStemp = _DSbuffer + 1 ; word DSvolts = _DSbuffer + 3 ; word DScurrent = _DSbuffer + 5 ; word DSthres = _DSbuffer + 7 ; byte DScrc = _DSbuffer + 8 ; byte ENDASM DSstat VAR BYTE EXT ; Status/Configuration DStemp VAR WORD EXT ; Temperature DSvolts VAR WORD EXT ; Voltage DScurrent VAR WORD EXT ; Current DSthres VAR BYTE EXT ; Threshold DScrc VAR BYTE EXT ; CRC
PBP can't use HighByte and Lowbyte because it doesn't know where the variable is when PBP is compiling. The location isn't known until it's Assembled.
Try it like this, which specifies the High and Low bytes as EXT too.
Code:DSbuffer VAR BYTE[9] BANK0 ASM ;Typcasting Variables inside of Arrays DSstat = _DSbuffer ; byte DStemp = _DSbuffer + 1 ; word DSvolts = _DSbuffer + 3 ; word DSvoltsL = _DSbuffer + 3 ; byte DSvoltsH = _DSbuffer + 4 ; byte DScurrent = _DSbuffer + 5 ; word DSthres = _DSbuffer + 7 ; byte DScrc = _DSbuffer + 8 ; byte ENDASM DSstat VAR BYTE EXT ; Status/Configuration DStemp VAR WORD EXT ; Temperature DSvolts VAR WORD EXT ; Voltage DSvoltsH VAR BYTE EXT DSvoltsL VAR BYTE EXT DScurrent VAR WORD EXT ; Current DSthres VAR BYTE EXT ; Threshold DScrc VAR BYTE EXT ; CRC Serout2 TX_USB, 84,[" DSvolts is ",bin DSvoltsH,bin DSvoltsL,13,10]
